Replacement Navigation DVD Player
Old 07-26-2022 | 11:48 AM
leakingpinion's Avatar
Hey all,
I have a 2007 TL Type S which has an aftermarket head unit installed which has a crossover installed where the DVD player was, hence my nav screen just showing up black. Do you guys know if any year DVD player will do just fine or even an aftermarket? Stock ones online are very expensive - thank you for the input!
Old 07-26-2022 | 11:50 PM
Ratm68's Avatar
So you're trying to get oem navi to work with aftermarket radio? your navi dvd should be in the trunk so all you really need to do is the 68omh resistor mod to trick the system to think the factory radio is still plugged in. rather than pulling out the pin like in the post linked, i used t-tap to tap into and bridge the wire with the resistor in the middle. works just fine
https://acurazine.com/forums/3g-tl-a...system-956349/
DevtypeS
08-11-2012 06:56 PM
RAGINTYPE-S
02-14-2012 08:05 PM
new2me
04-02-2010 06:31 PM
Dwight.K.Schrute
07-28-2007 01:06 AM
bry_lee
10-08-2001 03:49 AM
Quick Reply: Replacement Navigation DVD Player
