Removing carpet to get to speakers
Old Sep 23, 2004 | 12:16 AM
sw1tchn1nja's Avatar
Has anyone done this, if so how. I am trying to install an RCA adapter off the subwoofer for my amp. I looked at it closely for awhile and couldn't figure out how to remove the carpet
Old Sep 23, 2004 | 12:05 PM
I have done everything, well almost everything to my car. you dont need to remove the carpet. Put it inside the door trim. I looks better and no bumps.
Old Sep 23, 2004 | 12:29 PM
I was gonna pull if off the sub in the trunk, that way i could control the level better up front...should sit up under the carpet pretty nicely, called Tweeter, spending the 55 bucks.. Thanks for your reply
Old Nov 17, 2004 | 04:24 PM
taschroth's Avatar
Where do you pull an output for an aftermarket sub... Do your use a line level adapater? Do you got to the OEM sub from the trunk or interior?
Old Nov 17, 2004 | 05:43 PM
ed99's Avatar
9.5+10.5 22m=Hella Flush
Some ppl are telling me we need a Line Driver to increase the signal from our OEM deck to the Aftermkt amp output. However, some ppl are just using a output converter that converts the speaker wires to RCA output that connects to the amp. Anyone used a LineDriver b/c it is recommended I heard. If not used, your amp might be working twice as hard due to lack of weak signal from our deck. Please comment if anyone has come accross this.
Jul 16, 2017 07:33 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
polish_pat
Sep 25, 2015 12:24 PM
