recommended sound-shops in NJ??
Old Sep 14, 2006 | 06:00 PM
BukvaMan's Avatar
i am pretty much done with my audio system. But the problem i have is that i just cant get it to sound right, well actually that would be just the subs. So i need a professional here to take a look at it and see what can be done and wich way it should be setup.
can anyone recommend anybody around north bergen area or wherever just not to krazy far
thanx
Old Sep 15, 2006 | 09:24 AM
rodneyc77's Avatar
Retired!!! ON TOP!!!
When you say that you "pretty much done with [your] audio system", what do you mean? What have you done? Did you use LOC to convert signals to amplifier??? etc.
With this information we can give you some feedback and such... Good Luck
Old Sep 15, 2006 | 03:23 PM
BukvaMan's Avatar
well everythink is hooked up all the components are in and all that is running trough rockford 3sixty signal processor. the mids and highs sound great the only problem are the subs. they dont really blend into the music and are not punchy enough. i dont know this is my first setup so i dont have no experience and have nobody to compare it to, thats why i need a proffesional to take a look maybe fine tune it or recommend different kinda subs and so on . NYC area is fine too, maybe even better. im right across manhattan.
again anyone that knows someone good please let me know. thanx
Old Sep 15, 2006 | 05:46 PM
TLscrappy's Avatar
Most amps have a phase switch. Change the one controling your sub and see if that helps the bass blen better with the music. As for the punchiness, can't help.
TLscrappy's Avatar
Most amps have a phase switch. Change the one controling your sub and see if that helps the bass blend better with the music. As for the punchiness, can't help.
emailnatec
29
Sep 28, 2018 04:27 PM
dirleton
20
Oct 16, 2015 01:48 PM
brocksolid
Sep 29, 2015 12:28 PM
San Yasin
Sep 29, 2015 10:52 AM
adreano17
Sep 29, 2015 08:48 AM
