Rear speakers not working
Old Jan 6, 2013 | 02:04 PM
muldsr01's Avatar
My kid left the rear dome light on at Christmas, because we were trying to get a DVD out of the DVD player that is mounted in the mid seat (where the cup holders would be). My battery died, and ever since I jumped my car, the rear speakers don't work (the sub does). Not sure if this is just coincidental or not. I usually don't turn my stereo up that loud, so I don't think I would have blown them out. But before I begin tearing everything apart, I was wondering if anyone could think of something simple that it could be. Outside of the DVD player being added everything is stock.
Old Jan 6, 2013 | 02:12 PM
Gregerst's Avatar
Something really simple.. how about checking the fade maybe it somehow got turned to the the front only.
Old Jan 6, 2013 | 03:53 PM
qurious9ss's Avatar
Do you have a separate amp for the rear speakers? If so check the fuse. Probably not your case, but I use to have a cap inline with my amp that would pop the fuse if my battery died and i jumped the battery before charging the cap.
Old Jan 24, 2013 | 11:11 AM
muldsr01's Avatar
It turns out it's just XM radio. Usually I listen to talk radio, so I didn't really notice. I switched over to FM and a CD, and the rears worked fine. Does XM radio only broadcast in mono?
Old Jan 25, 2013 | 02:32 PM
Gregerst's Avatar
Seems weird and you've tried xm music stations? If it only plays out the front I'd say there's something wrong with the HU.
Old Mar 26, 2014 | 10:21 PM
WhiskeyD's Avatar
Ever find a solution to this? I'm having the exact same problem. FM and AUX work fine but XM is only audible in the front speakers. At higher volumes you can hear the rears all distorted, but the sub is fine. Maybe xm doesn't support Dolby or something?
Old Mar 31, 2014 | 01:14 PM
muldsr01's Avatar
Yes, in my case, it was that the Dolby was turned to high. I think my wife may have messed with the settings, because I always had it turned off, and didn't even think to look in the most obvious place. Seems like the noise reduction completely takes out the rear speakers when you're listening to XM radio only. Weird. My whole audio set up is stock for the record.
AndrewS
19
Mar 14, 2024 06:59 PM
Feb 25, 2020 09:57 AM
acurajj
Sep 19, 2015 03:47 PM
alan_rich
Sep 7, 2015 11:08 PM
iRaw
ILX
Sep 5, 2015 12:10 AM
