Rear interior lights
Old Mar 17, 2012 | 04:00 PM
Westside_TL's Avatar
Does be one know how to remove n replace the bulb??
Old Mar 18, 2012 | 02:02 AM
A SiQ TL's Avatar
Originally Posted by VelfarreClubber
Got my leds the other day and been searching around the forum for a thread to explain the install, couldn't find a good one so i decided to create my own.
Tools i used. Thin flat head screwdriver, Leather man multi tool, Small tennis wrench, and rubber dish washing gloves.
Bulbs from superbrightleds.com
First step, use the wrench and pull out the interior light fuse. I've blown fuses in the Max switching bulbs before.
Next get the blade and jab it in here then pop the cover out
After you pop out each cover, put on rubber gloves and pull out the bulb. I found this to be the easiest method.
Now for the rear. Get the flat head and stick the tip in between the 2 covers, it should pop out and fall to the seat.
Door: Same as the rear pop in the screw driver into that location and the cover should easily fall out
Voila!, my pentax optio s40 cam doesn't take good pics of how good the domes look but heres the finished product.
Hope this helps
The rubber gloves are for gripping the bulb to pull it out. You can also use a strip of tape around 8" folded in half lengthwise (so it stays 8" long) to wrap around the bulb for leverage and pull it out.
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
handsom-hustla
Nov 13, 2015 05:04 PM
Ny1718
Sep 11, 2015 09:21 AM
brjones9
Sep 3, 2015 07:30 PM
