Rattle from subwoofer?
Old Nov 29, 2013 | 09:18 AM
gtfo's Avatar
Huge Member
I have a rattle coming from the rear deck, I think it might be a speaker cover over the sub? can i just pop that off? anyone else have this issue? 07 tl-s
Old Nov 29, 2013 | 10:08 AM
niebur3's Avatar
Really???? There are several threads that talk about this. Try searching!
Old Nov 29, 2013 | 01:38 PM
acrdr's Avatar
the rear deck comes out in one piece
speaker covers and all
PITA
most likely is your sub rattling
Old Nov 29, 2013 | 03:44 PM
Gil'sUA5's Avatar
Every sub on every 3G rattles and it rattles bad
Old Nov 29, 2013 | 04:18 PM
MacKenzie001's Avatar
Yup my sub was rattling against the metal its mounted too, the rear deck was rattling and the middle seat belt reel was rattling. Foamed under the sub, all under the rear deck and a bit under the c pillars and under the rear seat. Also completely removed the middle seat belt. Almost no rattles now, a little bit still with heavy bass but far improved.
Old Nov 30, 2013 | 12:10 AM
MarcoNorthPolo's Avatar
KCCO
It's a common problem. Design flaw on the part of Acura, if you ask me. There are various fixes listed in the forums, it's easy to find them.
Old Dec 1, 2013 | 10:16 AM
gtfo's Avatar
Huge Member
yeah i did find a thread, thanks guys
Old Dec 1, 2013 | 05:18 PM
Gnargasim's Avatar
Why isnt there a sticky for this in this section?
Old Dec 1, 2013 | 09:14 PM
bla8291's Avatar
After listening around from where the rattling was coming from, it was the strongest closest to the rear windshield. I pushed down on the liner surrounding the speakers and the rattle stopped. I had a piece of velcro that I folded over itself to increase its thickness, and wedged it between the liner and the windshield (from inside the car). No more rattle.
Old Dec 5, 2013 | 02:16 AM
DrTynanol's Avatar
after installing aftermarket subs, it went away..plus it the bass sounds so much better!
Old Dec 5, 2013 | 08:44 PM
KCCO
Absolutely right.
Old Dec 7, 2013 | 12:08 PM
Chad05TL's Avatar
take out the rear deck and look at the bottom. Where ever there is plastic touching metal, then cover it with duck tape or something. This includes around the mounting holes and the plastic flat "rail" pieces that provide rigidity to the rear deck... Then enter the trunk and secure the cable better that is the emergency latch opener. That cable was vibrating against the metal also. You probably wont get out ALL the vibrations.
AndrewS
19
Mar 14, 2024 06:59 PM
kb1rl
Sep 30, 2015 10:17 AM
jmaxima03
Sep 27, 2015 10:22 AM
jaynatlanta
5G TLX Problems & Fixes
Sep 15, 2015 11:08 AM
3GTLOwns
Sep 9, 2015 09:51 PM
