Range on factory remote on 2005 TL??
I have a 2005 TL and I stupidely went to Acura to get a automatic starter to be installed (a while back) from them since I didn't want a aftermarket one installed by someone else and void the factory warranty. I've noticed the range sucks like hell even just opening my locks or unlocking it. i literally have to get 5-10 feet and then it works (even with the automatic starter is the same thing). I've changed the battery on the remote too and still the same thing.
Both my remotes have this issue not just one!!
Anyone experience this or is this something wrong with the car?
I didn't even know Acura made an OEM remote start for the TL. I'd double check to see what they installed in your car. It's probably an aftermarket that they warranted because they did the install for you.
^^^ +1 i wasnt aware of this either... how much they charge? IIRC they do for newer tl's but not the 3g??
Plus my range sux too.. try putting the remote up to the bottom of your chin at further distances. Works wonders!
My experience...
Mine works from about 150 feet. Yes, the range seems to improve if you hold the key fob under your chin... but only an additional 30-50 feet.
To answer your question: Yes, I think something is wrong with yours. Probably in the receiving end of things if your battery is fresh.
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
SinCityTLX
Oct 7, 2015 01:24 PM
