Radio help
Old Mar 8, 2013 | 08:02 AM
purplehaze9414's Avatar
Radio help
I had my battery out of my car put it back in... put my pin in to unlock nav comes up but no radio and up top where the temp setting is at it says code. What happened n what do I do???
Old Mar 8, 2013 | 08:05 AM
there are two codes.
One for the navi
and the other; yep you guessed it, is for the radio.
SharksBreath's Avatar
BANNED
you need to put in your radio code...
don't have it? chech the left hand side of the glove box, might be on a white sticker.
no luck? call the dealership where your car has been serviced. ask them, and then WRITE IT DOWN.
Old Mar 13, 2013 | 11:03 AM
Rob1704's Avatar
Having same issue as OP. Purchased my 05 TL used and did not get the codes. Sticker is not in the Glove box, don't have the owner's manual. Called the dealer that sold the car new and they gave me the codes (nav and radio). Nav code works but when I type in the radio code I get error1. Tried again and now have error2. Dealer says it is the right code and if I keep trying it will eventually lock out the radio.
Perhaps the radio was replaced and now the code is different? Any ideas? Would love to hear what the system sounds like
Old Mar 13, 2013 | 11:08 AM
i think you would have to take the head unit out and see the bar code or serial number. and then call alpine or who ever makes the head unit.
I think there is a secret menu that shows the serial number but im not sure
BANNED
^doubtful that it was replaced. its a 5 digit code they gave you, correct?
and you just hit the preset numbers, right?
still no workie? remove that radio and it'll be printed on the unit itself. sucks...but thats one way to do it.
Old Mar 13, 2013 | 11:34 AM
Rob1704's Avatar
Right- 5 digit code and I type it in using the preset buttons. Called local dealer and they said to push and hold preset buttons 1&6 with one hand and then turn the radio on with the other hand and it will display serial #. Wife has car. Will try later and report back.
Old Mar 13, 2013 | 04:11 PM
RenoTL's Avatar
Having the code on the unit sort of defeats the "security" of having a code. I thought the code was to help make it harder to steal and then use the radio.
Old Mar 13, 2013 | 08:25 PM
Rob1704's Avatar
Yep this works. With the ignition on and the radio off (meaning that it does not say "code" on the screen above the nav) you press and hold the 1&6 preset buttons under the radio and while holding them push the radio power button. The screen above the nav will then display a letter and 4 numbers and then another letter and 4 numbers. This is your radio's serial #. Call your dealer with this number and they will give you the radio code. NO NEED TO PULL THE UNIT OUT!
dirleton
Aug 6, 2024 08:19 PM
Puma Jim
20
Oct 20, 2016 11:59 AM
SinCityTLX
20
Oct 19, 2015 11:23 AM
jdmaszfcuk
Oct 19, 2015 12:31 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
