radio doesn't illuminate...please help!
Old Oct 4, 2007 | 08:14 PM
draztic1011's Avatar
I am about to purchase an 05 TL. It is equipped with navigation yet at the moment, it is asking for the code which i don't have yet. My problem is, when I turn on the lights, everything illuminates (all the instrument panel buttons) except the radio, where the 6-cd changer is. Is this normal? Will it illuminate when the code is put in?
Old Oct 4, 2007 | 09:12 PM
ARX-01b's Avatar
yes once the code is accepted it will light up
Old Oct 4, 2007 | 09:35 PM
thanx a lot!!! I thought i was getting a car with problems.
Old Oct 4, 2007 | 10:12 PM
if anyone else knows this, please chime in to confirm.
Old Oct 4, 2007 | 10:16 PM
csmeance's Avatar
radio won't light up until the code is put in. The code should be a sticker near or around the glovebox area, make sure to look by the latch and the sides of it as acura dealers stick it there brand new.
Old Oct 4, 2007 | 10:41 PM
also, where could i find the navi code?
Old Oct 4, 2007 | 11:12 PM
csmeance's Avatar
it should be with it, its one sticker with both codes to my knowledge, the 4 digit one is for the navi and the other is for the radio.
Old Oct 5, 2007 | 02:11 AM
Will Y.'s Avatar
Registered but harmless
Both the Navi and radio codes are on a card given to the original buyer with the owner's manuals case for the glove box. There are also stickers with the codes, which techs will stick on the glove box.
Ask for the owner's manuals (car manual, Navi manual, warranties for car and tires) packet. Also check the trunk and the spare tire compartment under the trunk floor if the codes aren't in the case in the glove box.
Finally, check Acura link to see if the previous owner or dealership registered your car and put the code info. onto the site.
Old Mar 24, 2008 | 07:19 PM
tomz_TL's Avatar
I have the same problem with the radio not working. I found two stickers, with this info:
One has these numbers: 11102836;
The second has these: EKB22003664
Is either of these the radio code???
Old Mar 24, 2008 | 07:31 PM
007TL-S's Avatar
Be kind to us truckers !
i think this the radio code, just the #'sEKB22003664 the othervis the navigation.....if these are what on your car....if not consult with your local dealer!
Old Mar 25, 2008 | 07:57 PM
tomz_TL's Avatar
I got the code from the dealer! Thanks for your help!
dirleton
Aug 6, 2024 08:19 PM
Puma Jim
20
Oct 20, 2016 11:59 AM
SinCityTLX
20
Oct 19, 2015 11:23 AM
jdmaszfcuk
Oct 19, 2015 12:31 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
