Quick front LED resistor question
Old Aug 18, 2008 | 12:40 AM
bforbrian's Avatar
So I installed a switchback led 7443 (2004 TL) on the driver's side but seem to have probs with the passenger's side.
The passenger's side has 3 wires (as does the driver's side) but slightly different coloring. One is black, one is red, and one is white. I know black to be grounding but which is the parking light? The resistor needs to be tapped into grounding and parking but I seem to be having problems with the quick blinking rate.
So red or white for parking lights? I searched thoroughly on ALL the led threads and couldn't pin point which color.
Old Aug 18, 2008 | 12:13 PM
Trew's Avatar
Resistor Connects to Turn Signal Wire
The resistor should connect to the turn signal wire and the ground. Not the parking light wire. I'm not sure of the color, but you have only 2 wires to choose from. tap into the red one and see if that works, if not, just tap the white. Black is ground.
Old Aug 19, 2008 | 12:31 AM
bforbrian's Avatar
Oh yeah that's what I meant.
I installed on the ground (black) and white (probably parking because the blinking rate on the switchbacks have been equalized).
No problems.
Old Nov 9, 2008 | 06:36 PM
chuanger's Avatar
One or Two?
Which resistors did you purcahse/use? I tried using the 50 W 6 Ohm resistors from V-leds and they don't seem to be working.
http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481
Old Jan 3, 2009 | 12:41 AM
xrvman's Avatar
2008 NBP
Where did you get the switchback led's
Old Jan 3, 2009 | 09:50 AM
Trew's Avatar
I did a search and found a few posts and read through them and used the links I found to purchase the switchbacks.
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Feb 25, 2020 09:57 AM
TLDude876
Dec 28, 2016 03:18 PM
08 NBP TL
Sep 8, 2015 08:49 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
