Question TL 05 Navigation
Old Oct 13, 2007 | 04:56 PM
tytsupercharged's Avatar
When I am turning on the headlight, does the navigation suppose to be dimmed or the brightness like in the daylight? If not, how to fix it
Can you guys confirm this?
Old Oct 13, 2007 | 05:07 PM
ggesq's Avatar
Yes, normally it will dim once you turn on the headlights. However, if you want it to, you can change the settings to max brightness and it will stay light up as if the lights were never turned on.
Old Oct 13, 2007 | 05:11 PM
Even I am not turning the max brightness and turning the headlight. The backlight of the navigation still very bright like daytime. Any suggestion? Thanks
Old Oct 13, 2007 | 06:09 PM
kenny5's Avatar
Just turn off the max brightness button, and adjust the night brightness level with the set up screen.
Old Oct 13, 2007 | 07:16 PM
VQPower37's Avatar
just go into setting and change the light setting to auto
Old Oct 13, 2007 | 07:27 PM
csmeance's Avatar
go to setup and make sure it is in auto, second change the guage brightness to down 1 with the lights off and then turn the lights on, and put it to your desired night time brightness.
Old Oct 14, 2007 | 09:58 PM
Thanks a lot
BoricuaTL
Apr 8, 2016 01:08 PM
navtool.com
ILX Audio, Bluetooth, Electronics & Navigation
32
Dec 22, 2015 12:46 PM
navtool.com
ZDX
Oct 31, 2015 08:26 PM
navtool.com
Sep 25, 2015 06:21 PM
datadr
Sep 12, 2015 09:12 PM
