Question TL 05 Navigation
When I am turning on the headlight, does the navigation suppose to be dimmed or the brightness like in the daylight? If not, how to fix it
Can you guys confirm this?
Yes, normally it will dim once you turn on the headlights. However, if you want it to, you can change the settings to max brightness and it will stay light up as if the lights were never turned on.
go to setup and make sure it is in auto, second change the guage brightness to down 1 with the lights off and then turn the lights on, and put it to your desired night time brightness.
BoricuaTL
04-08-2016 01:08 PM
navtool.com
ILX Audio, Bluetooth, Electronics & Navigation
32
12-22-2015 12:46 PM
navtool.com
09-25-2015 06:21 PM
