Question on Aftermarket Subwoofers
searched the forum and found a thread that said if i get http://www.crutchfield.com/S-APqN6MG...s.html?tp=3097
i can hook up my subs+amp to the wires i already have.
is it really this simple? because a guy at one of the local audio stores said 200$ to install. And i dont have 200$. So i wanna hook it up my self
That adapter allows you to connect speakers to your factory harness.
I used that when i changed out all my interior speakers.
Definitely worth using since the length of the sub cable is short.
You connect the harness to the plug. Then a LOC to the ends of it.
From there you use RCA cables from the LOC to the amp.
You will still need to run a power wire and remote wire. In addition to ground.
all it does is make it so you dont have to cut the plug off
aftermarket speakers have simple posts for the wiring to be solderd on
oem speakers (of any car company) have propriatary connections on the end of the wiring like a ps2 connector for your keyboard and if you get the ps2/usb adapter to plug it in anywhere
AndrewS
19
Mar 14, 2024 06:59 PM
Hau_nguyen91
Sep 6, 2015 12:53 PM
trinikidcl
Sep 4, 2015 12:56 AM
