Question about iPhone and HFL transfers.
Received 6,470 Likes
Guys, I just got an iPhone on Thursday. It paired up perfectly with my Type S.
On my old phone, if I was talking on the device, once I got in the car, I just pressed the HFL button on the car and said "Transfer". The call would then go to the car and to the HFL.
With the iPhone, if you're in the car and it's paired up, and if you call a phone number from your iPhone, you get 3 options in the iPhone screen:
1) Hands Free Link
2) iPhone
3) Speakerphone
If I press the iPhone or Speakerphone buttons on the iPhone, the call dials from the iPhone. But if I press the Hands Free Link button, I don't hear any dialing-either from the phone or the HFL in the car.
So my question is:
1) what is the Hands Free Link button on the iPhone screen for and how do you use it?
2) if I press the HFL button on the car while the iPhone is dialing, the car says, "no number is being dialed." But when I did it with my other phone, you could hear the phone dialing thru the car speaker and the HFL.
Also, what is the proper procedure to transfer a call from an iPhone to the car's HFL or vice versa?
1) Hands Free Link
2) iPhone
3) Speakerphone
So my question is:
Plus, one other question. I have a 2007 Type S. Will the Phonebook in the iPhone transfer to the Hands Free Link in the car?
Driven to Perfection
Good question, I've been trying to figure out the same thing. Specifically, how to dial a number with my iPhone 3G and transfer it to HFL. Can't get it to work using the button on the iPhone, or by using the "transfer" command with HFL.
And the Phonebook does import. Although Acura's implementation is clumsy.
I talked to ELEGANT TYPE S and he confirmed that you can only transfer a call from an iPhone AFTER you've begun talking to that person.
Wants an M3 in
Gentlemen,
I figured this out a while back. The redial method wastes a lot of minutes. What you must do is dial with the iphone connected and then hit handsfreelink when they pick up. It kind of sucks that HFL doesn't get the command when the phone dials but it does get the transfer command from the phone. Nothing is perfect I suppose.
Gentlemen,
And yes, the iPhone does connect to the phonebook in the car and can transfer contacts.
Yea...I was reading the owner's manual last night and I think it says that if you want a dial a number from your phone book that you have to let it go through the entire list of names in the phone book. Is that really correct??? Can't you just say, "Call Mattster, mobile" and it would go right to your name and cell phone number and dial it
...but it looks so awesome in that TV commercial...
Gentlemen,
That's right. The voice recognition doesn't seem to be true voice-to-text type recognition. Instead, for each name in the HFL system, a voice fingerprint is recorded then associated with the appropriate contact. So imported names from the phone are stored in the phonebook, but you have to transfer the contact to HFL and record a name for it before you can dial by voice.
I actually called the toll free HFL Customer Service number on the Acura website. Wow...they were VERY helpful. I talked to a young lady who really knew her stuff.
Plus, if you add anyone to your phonebook on the iPhone, the car will not automatically pick it up. You must delete your phonebook and then reload it into the TL.
I have setup only about 3 numbers using the voice command thing, but i did pair my phonebook. I almost never dial from the iPhone and then switch to HFL, because during the pause almost everyone hangs up on me. So if I don't dial one of the 3 numbers i have set voice commands for, i just find it in the phonebook and dial it there.
my biggest complaint is that if you setup the voice volume to hear the person on the phone properly the hfl lady yells "DIALING THE NUMBER RECEIVED FROM THE NAVIGATION SYSTEM!!!!!!!" then ur like omfg turning the dial way down, then when someone answers the phone you barely hear anything (especially on the highway).
Being an Acha Bacha in
OK guys...one more question about this stuff. Today, I was talking to someone while I was in a store. I walked to my car, turned it on, but wanted to transfer the call I was already on to the HFL-once the car was on and the iPhone was linked to the car upon starting the car. Can you still press the button on the HFL and say "Transfer" and the call will transfer to the car's HFL?
Actually, you should do both. First, you should record frequently called people and put them in your HFL. But if the 2005 will download the phonebook, that's where you'll have the rest of your contacts on the TL. But I'm not sure if the '05 will download the phonebook. It might have been a feature in the newer models.
I think the phonebook import is an 07-08 option.
As far as the transfer from iPhone to HFL I did it once but it was very cumbersome since I didn't know of the Transfer command, so I hit the talk button on the HFL and the blutooth option on the phone and possibly hit
talk a few more times and it transfered. However there were many "hello you there?" from both sides so I wasn't very smooth.
Sometimes it will transfer automatically if the phone is brought back within distance of the HFL and the car is already on. For instance I was at the carwash the other day and the car was about a good 20-30 ft away. I was inside the office on a call. I walked outside to get some fresh air and suddenly I heard my call being blasted through my car cause the carwash guy had the ignition on and the stereo turned up. I had to hit iPhone to switch the call back to my phone...lol
Otherwise, like you already posted, It's only when you initiate a call from the iPhone that you have to wait till the person on the other line picks up before you can transfer the call over to HFL.
^^^That's good to know-I'll have to try that out.
on my 06 Non-Navi, when I walk to the car and turn it on while in the middle of a call, I just hit the HFL button the iPhone screen and it transfers instantly.
But that HFL button on my iPhone doesn't stay on all the time for me. How do you get back to that screen or does it stay on all the time for you?
bothersome glitch
I read this thread with hope that someone had figured out how to dial from the handset but not have to wait until the call was answered (and then hit HFL). This is one of those quirky little things that gets under my skin.
I need a "there's an APP for that" about now. I'd actually pay for it!
TJ, it's a software issue. It's just one of those iPhone things....sorry.
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
Eggs999bacon
09-24-2015 10:08 AM
