Problems with Line Out Converter and After Market Amp. NO OUTPUT!
04 TL. Need your help?
Installed amp and line out converter today and there is no output. No power to the subs.
Here's how I installed it.
What am I doing wrong here? Can the LOC Power and Ground connect straight to the amp? Or not? Is the sub wire a low output or high output signal?
Thanks, all your inputs are appreciated!
LOC: PAC - SOEM-T 2 channel http://www.pac-audio.com/productDeta...&CategoryID=28
Amp: MB Quart FX2.60
- Disconnected and Tapped the Sub wire
- Ran the converter Power, Ground and Remote to amp
- RCA cable connected from LOC to amp.
Last edited by miltownacura; 10-16-2011 at 11:35 PM. Reason: Added car model and year
Yes, the sub setting is up. I don't know! I'm out of ideas on how to make this work. Could it be because there is no signal from the Sub wire?
I just realized one thing about my install. I disconnected the sub wire from the factory sub and tapped it because I didn't want my factory sub to run.
Could disconnecting the sub wire cause a no signal through the wire? Thus no signal is going to the LOC.
cycdaniel
12-17-2019 10:58 AM
sockr1
10-01-2015 01:31 AM
Pegon95
09-15-2015 01:54 PM
