problem with my bluetooth
5th Gear
ok so I can make outgoing calls but I can't recieve them anymore...the bluetooth won't pick up calls in my car anymore...does anyone know why?
Another question
Are you saying that you can receive calls (while bluetooth on your phone is enabled) but you don't hear a ring from the car but you can answer the call via the phone?
I'm trying to confirm you can at least get calls while the Bluetooth is active.
Example: enable bluetooth on the phone, the car shows a telephone icon on the dash, you can make a call by dialing out (e.g., using the "call xxx" voice command), someone tries to call you, and then your phone rings and not the car? or neither the phone nor the car rings?
Also, you can send/receive calls when not connected via Bluetooth?
Dennis
Dennis
5th Gear
that's exactly what i mean.....while connected to bluetooth I can recieve calls but my car won't ring, but I can use my car to make calls out....so it's only working one way.
SidhuSaaB
05-30-2020 12:40 AM
navtool.com
31
11-16-2015 08:30 PM
SUPRMN84
10-07-2015 09:46 PM
navtool.com
09-25-2015 05:15 PM
