Problem Iphone on Bluetooth
Old Jan 17, 2008 | 11:29 AM
Sqweak's Avatar
i'm having a problem with trying to hook my iphone up... is there something i have to do on the car's side to have bluetooth...
thanks
derek
Old Jan 17, 2008 | 12:37 PM
GLowrdr's Avatar
Don't feed the...WTF?
Have you paired the phone with the car yet? Sorry if this is too obvious of an idea, but it sounds as though you may not have?
Old Jan 17, 2008 | 12:55 PM
Sqweak's Avatar
maybe that is my problem, the the blackberry i had i turned on the bluetooth and the car found it.. but when i turn it on the iphone... no luck.. so i think i'm doing something wrong
Old Jan 17, 2008 | 01:07 PM
Kwangmin's Avatar
with my iphone i have to turn on bluetooth before i start the car in order for it to connect. if i turn on bluetooth after the car has already been started it won't connect.
Old Jan 18, 2008 | 12:17 AM
Kama45's Avatar
3rd Gear
Wait...I assume you ran a new phone set-up through your car?
Old Jan 18, 2008 | 01:20 PM
jzacuto's Avatar
If you have paired the device with the HFL, the BT feature on the phone has to be turned on when you start the car for HFL to re-link to the device automatically. If you enable BT on the phone after the car has started, the HFL might not always re-connect automatically.
Also, some phones (like BlackBerrys) will prompt you when the HFL attempts to link to your phone. The BlackBerry gives you the option of checking a box that tells it not ask again so that the next time it links you don't have to do anything else. Check that box and click "Yes" to connect to the HFL.
It's possible that the iPhone has the same kind of option.
Good luck!
Old May 9, 2008 | 11:27 PM
xen-cuts's Avatar
ROFLCOPTER!
okay, i have an iphone and its pairing is horrible. If i dial from the phone, then it won't pick up in the HFL (even though it offers the option to transfer it to the car, keep it on the phone, or something else that I cannot recall now). HFL will also not transfer back to the phone when you want to get out of the car. WTF???!!!! This pisses me off.
My crappy FREE samsung could at least accomplish these simple tasks, albeit in the usual poor bluetooth kind of way. Anyone got suggestions? I think the bluetooth firmware needs updating or something...
Old May 9, 2008 | 11:39 PM
flydog's Avatar
How would the phone know whether you want to use the car or the handset? All you need to do is push a simple button. Not the end of the world. And when you turn the car off, if you are in the middle of a call the HFL stays on until you transfer. So its not that inconvenient.
Old May 11, 2008 | 07:49 PM
xen-cuts's Avatar
ROFLCOPTER!
Okay so your reply isn't helpful.
Essentially, my old phone always gave me the change to change from HFL to headset as an option. When I wanted to leave the car, I didn't have to stop the conversation and switch...the phone just did it OR gave me the option to do it.
Stupid iPhone = nothing! I have looked through installer to fix this but haven't seen anything yet. Anyone got something that IS helpful (not just a suck it up statement... )
Old May 12, 2008 | 11:02 AM
Kama45's Avatar
3rd Gear
Yeah, dialing from the iPhone is worthless. I just dial using HFL. It can be annoying at times.
Old May 12, 2008 | 11:35 AM
xen-cuts's Avatar
ROFLCOPTER!
I wish someone like the Ziphone guy would fix this for us... I don't know enough about programming to add anything.
SidhuSaaB
May 30, 2020 12:40 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
tristann616
1/2G MDX (2001-2013)
Sep 22, 2015 11:40 PM
