Please help. Weird Navigation problem...
Old Nov 10, 2007 | 06:07 PM
tlty21's Avatar
5th Gear
Several weeks ago my Navigation sytem quit booting up when I start the car. Each time I start the car the "Acura Navigation" wallpaper comes up and just stays there. The sytem never boots up. It then cycles through between that screen and the "code" screen. However...I am not able to touch the screen to do anything at all. I have taken out the navi disc and put it back in, but it still says frozen on that screen. Is there a way to "reboot" the system?
I never had any problems before and I haven't had the battery die on me or anything? I've searched this forum and the internet and I can't find anyone who has had any similiar issues... any help or input would be greatly appreciated.
Old Nov 10, 2007 | 06:19 PM
KJSmitty's Avatar
WDP Director of R & D
This is by no means a smart alik question,,, but are you out of warranty??
Then again, I bet someone on the forum has experienced this. I myself cant help ya - I wonder if the disk drive is bad.
Good luck
Old Nov 10, 2007 | 06:20 PM
lusid's Avatar
FTW
whats the year of your TL?
Unplug battery and replug it?
Old Nov 11, 2007 | 07:26 AM
tlty21's Avatar
5th Gear
Good luck
Yes I am out of warranty
Old Nov 11, 2007 | 07:27 AM
tlty21's Avatar
5th Gear
2004 TL
Old Nov 11, 2007 | 04:19 PM
TL-ed's Avatar
Wake up and drive
1. Remove DVD
2. Unplug both battery terminals for 30mins (make sure you have Radio/Navi code)
3. Reconnect battery
4. Start up the car - enter navi code
5. Insert DVD
6. Restart the car
7. It will goes through the DVD download process
It should work now. If it still doesnt work then it could be a hardware issue. Do you TVandNav2Go installed or anything else with the navi?
Old Nov 13, 2007 | 11:31 PM
tlty21's Avatar
5th Gear
Weird Navigation Issue
Ok...I followed your instructions to a T. I thought it was going to
work, but as soon as I started to enter the nav code... I was able to
get one number in and then the nav system started to cycle through
again. First the nav wallpaper screen then back to the code screen.
I tried to enter the code again...and it just keeps going in that cycle.
Ever hear of something weird happening like that????
Old Nov 14, 2007 | 12:33 AM
TL-ed's Avatar
Wake up and drive
keep the DVD in. disconnect and reconnect the battery again after 5 min and enter the code. Again do you have anything else installed on the navi unit?
Old Jul 15, 2008 | 01:19 PM
melvin2816's Avatar
05 TL NBP 6spd S front
TL-ed Your advise works
I had similar problem
I finish installing a sound system to my car and since I had the battery disconnected for a while the NAVi asked me for a code. At first I though one code for everything not knowing that radio and navi are seperate codes.
My problem i did not had the codes.
I notice in another thread that sais the radio code and navi code are in the club box on the side white sticker .
But my navi screen when black screen because i put in the wrong code more than 3 times.
I follow your step and I was able to input the codes that I found inthe club box and I am a happy camper :gheywave:
Thank you
TL-ed
dirleton
Aug 6, 2024 08:19 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
TLguy42
Sep 26, 2015 11:27 AM
