Please help with sub/amp problem.
Old Sep 6, 2007 | 08:35 PM
ajil's Avatar
Okay I have an 05 tl non navi. I have been working for the past couple of days trying to get my JL audio 300/2 amp and 10w3v2 sub installed.
I have tried with an loc, and without (my amp has the switch to take high level input, you just need to splice a rca cable into the sub wires). No matter which method I try, I get the same problem. The amp powers on fine (at least the green light comes on) but no matter how I mess with the HU settings or amp settings, the sub barely gets any power. I have to put my hand on the sub to feel anything. I can't figure out what the problem is, and I really wanting to finish up with this project. It has already been on hold for 2 months while my car was at the dealer. Any suggestions are welcome, thanks in advance.
Old Sep 6, 2007 | 08:58 PM
Kennedy's Avatar
OMGWTF4THGENTL
Responded to your PM...
Provided you set the signal sensitivity to properly turn on the amp, set the gain right, and set the filter properly... It should fire right up.
Otherwise, sounds like a bad amp.
Amp used?
Old Sep 6, 2007 | 09:14 PM
King of Pain's Avatar
Amp used?
I am assuming that you have it bridged for 300 watts since that's what the sub needs and have played with your gains/settings and all the wiring is correct then I would agree that it's a bad amp
Old Sep 6, 2007 | 09:31 PM
csmeance's Avatar
uh.. make sure the wires aren't reversed for the RCA where you tapped into the stock subwoofer wires.
Old Sep 6, 2007 | 11:50 PM
ajil's Avatar
kennedy answered the problem via pm, when did my homemade rca to speaker input splice job, I didn't wire it up correctly. Thanks for the help guys.
Old Sep 7, 2007 | 01:07 AM
ajil's Avatar
man having a sub is awesome. I forgot how much I missed it. One question, should I turn the rotary control (which I think is the gain) up or down any? It came pointed sat 12:00, and turns both ways. I definately don't want to blow my speaker, but I don't wont to be wasting any potential power either.
MilanoRedDashR
Oct 8, 2015 10:30 AM
thegipper
Sep 28, 2015 01:01 PM
hrothgar02
Sep 28, 2015 11:08 AM
ceb
ILX
Sep 27, 2015 10:56 AM
prbori
Sep 27, 2015 01:37 AM
