Please Help Aftermarket Sub Problem!!!!!!!!!
Old May 28, 2009 | 10:12 PM
Vini's Avatar
GR8TL
I had a 10" JL Audio W1 put in my car today, they disconnected the sub and used those wires for the signal, also disconnected the mic in the rear that everyone says was giving them problems, The sub sounded so bad it made the stock sub sound great, the installer said he had to tap into the rear speakers to drive the sub and it sounded a little better but I lost sub control from the stock radio. What gives? Any ideas?
Old May 29, 2009 | 08:52 AM
csmeance's Avatar
did they hook it up to an amp? If not, its probably not getting the right wattage.
Old May 29, 2009 | 09:03 AM
Tumbleweed13's Avatar
If they are using a high level input into an after market amp, they need to tap into the speaker signal before the factory amp. If he is taping into the signal at the rear speakers they have already gone through the factory amp and the built in crossover, which is why it doesn't sound right.
Old May 29, 2009 | 09:55 AM
Vini's Avatar
GR8TL
Thanks, I think that is what they did.
Old May 29, 2009 | 09:56 AM
Vini's Avatar
GR8TL
Yes I'm using a fosgate amp with enough power for a 10" sub.
SidhuSaaB
May 30, 2020 12:40 AM
tristann616
1/2G MDX (2001-2013)
Sep 22, 2015 11:40 PM
Silverstead1
Sep 17, 2015 06:45 AM
christopher1
3G MDX (2014-2020)
Sep 10, 2015 06:43 PM
trinikidcl
Sep 4, 2015 12:56 AM
