Please help!!
Old Jun 27, 2007 | 05:17 PM
FMS818's Avatar
3rd Gear
Please help!!
ok..I have an 07 Acura TL s. The car is great but im having trouble with one thing. I am putting a brand new complete sound system in it and im almost done.
But now i am at the point where im puting the stereo back in. But when i start the car its nav. works but the audio doesnt...I hope this made sense...PLEASE HELP
Thanks in advance.
Old Jun 27, 2007 | 07:02 PM
FMS818's Avatar
3rd Gear
Can anybody help me??
Old Jun 28, 2007 | 01:40 AM
csmeance's Avatar
are you using stock Head Unit? Where did you tap for signal, after the facotry amp or before the Amp? If after the Amp, do you have a high input aftermarket AMP or did you use a Line out converter? If before the amp, did you use a line driver to increase the wattage to make it suitable for the aftermarket amp? Did you pput in any other devices such a a 360 sound proessor? Did you check the wires and gorunds to be hooked up right? Does the AMP power on? Are the speakers properly secred and wired correctly?
Hope this can help me help you.
EDIT: did you put in an aftermarket sub? if so, you have to disconnect the mics for the active noise cancelation as the sub will produce a thumping nosie with the stero off.
Old Jun 28, 2007 | 09:30 AM
TSC17's Avatar
2012 SH-AWD / Advanced
Yeah, what he said...
Old Jul 31, 2007 | 11:45 AM
cocokola's Avatar
Is the noise cancelation only active when the stereo is off?
Old Jul 31, 2007 | 12:43 PM
rodneyc77's Avatar
Retired!!! ON TOP!!!
Input the Radio Code... using the preset buttons...
