Noob with a few questions 3G TL
so i just picked up a 06 TL and i have done my research and still have questions so here we go!
none of my roof dome/map lights work due to no power at the front 2 dome lights
wiring diagram im going to be looking for this wire today i hope and i think i seen somewhere it goes into the back of a grey modual is this correct?
door, trunk lights work
blue tooth does not work probably because of no power also
but the Bluetooth isn't a big deal probably will never use it
unless i can stream music through it
does the 06 have DRL or just 07 08?
thats all for now thanks!
I can't answer about the roof/ dome light, but:
-bluetooth modules have a tendency to go bad in these cars, but can be easily replaced with a new module
-bluetooth in this car can not stream audio- it is located in the plastics of the front roof console, where the sunroof switch is and comes out in 5 minutes. Ridiculously easy removal.
-the 06 never came with DRL's, but if you want them, in general, rewire the existing foglights to a separate switch and install 03-05 Accord foglights in the lower bumper as many have done here. These can be switched to the factory foglight switch.
Check the 3G Garage as all the info you need is in there.
Welcome to AZ.
Check the driver's side under-dash fusebox to see if the console/HFL fuse is in place-- the prior owner may have pulled the fuse for the HFL/Bluetooth (rather than just disconnecting the HFL itself) if the unit is bad, but the fuse also connects power to some lights and accessories, IIRC.
Welcome to AZ.
Welcome to AZ.
everything hooked up to fuse 6 works except the dome lights on the roof and the hfl
there is no power to the plug for the dome lights in the roof but everything else that the previously posted diagram says is hooked to fuse 6 has power!
i am thinking there is a broken wire
im going to pull the kick panel and check things out in there
what is the grey relay box on the kick panel MICU
is that what makes the dome lights dim off?
so i got the wire fixed for the dome lights it was broken about 1/2 from the plug that goes into the grey relay box on the interior kick panel.
also when i pulled the underdash panel a wedding ring fell out!
my lucky day huh!
i also figured out if i leave the light on they shut off when you lock the doors!
bluetooth still dont work but i dont think its running down the battery!
my lucky day huh!
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
