NEED HELP...XM Radio
Old Feb 24, 2011 | 09:59 PM
hatchconversion's Avatar
Ok so about 3 months or so ago I installed a Isimple peripheal setup for my ipod to play through my xm controls. Great right???.... Well it was and I loved/love it. However about a month ago it took a few tries pushing the xm button to get it switched over to xm to play my ipod (acura tl 3g no navi). It continued to do that but still worked for a while. Now it wont even go to the xm side of it at all. I simply try over and over and it dosnt make a noise or even try switching to xm/ipod controls. I have tried to unplug my ipod and replug and try it without the ipod and also reconnect the isimple box and still no dice. All other buttons function fine (am/fm, cd, etc). If any of you guys have ran into this problem but have an idea what it may be, please let me know.
Thank you!
Old Feb 24, 2011 | 11:49 PM
A SiQ TL's Avatar
I don't know about the isimple , but I've had that happen with my DICE unit and I had to unplug it from power for a minute, and then plug it back in. I would try that again, and recheck ALL your connections, maybe something came loose.
Old Feb 25, 2011 | 05:15 PM
i did, but i will see if theres an update and put it back in. hope to get it fixed soon. these cd's are not cutting it.
Old Feb 28, 2011 | 08:16 PM
Updated my isimple firmware and still have the exact problem as before. XM is still not switching over or even acting like it is working. Please someone help me out if you have expereince in this or ideas.
thanks
Old Mar 1, 2011 | 11:58 AM
A SiQ TL's Avatar
If you had navi, I'd say check the diagnostic mode;map,menu,cancel, to see if the xm is working correctly (green). I don't know how that would be done on non nav. Maybe disconnect the cars battery for a few minutes to see if it will reset anything.
Just make sure you know your radio code before you do that.
Old Dec 10, 2012 | 10:47 AM
warrior15r's Avatar
Thank you!
I'm experience the exact same problem. I hit XM to use my DICE unit because it doesn't switch to XM at all. Did you ever get this resolved?
dirleton
Aug 6, 2024 08:19 PM
Puma Jim
20
Oct 20, 2016 11:59 AM
SinCityTLX
20
Oct 19, 2015 11:23 AM
jdmaszfcuk
Oct 19, 2015 12:31 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
