Need help using a loc for rear sub
Old Jun 26, 2010 | 06:35 PM
JackSampson's Avatar
Yeah I tried searching but I could not find a thread specifically on installing a loc off the rear sub for an aftermarket upgrade. The loc I have is a pac sni 35. It has 2 pairs of wires. I can not tell which pairs to connect to the rear sub wires. Also are the ground wires on the loc needed?
Old Jun 26, 2010 | 07:36 PM
King of Pain's Avatar
Taken from the PAC Website:
SNI-35 converts 2 to 40 watts per channel speaker level output into a pre-amp signal. Perfect when adding an amplifier to a factory or aftermarket radio. Great for getting an additional set of pre-amps outputs from a head unit equipped with only one set.
• Fixed 10:1 conversion.
• Linear from 20-20,000Hz at +/- 5 dB, while maintaining signal phase.
• Isolates input and output circuits to prevent ground loop noise.
White: Left(+) speaker
White/Black: Left(-) speaker
Grey: Right(+) speaker
Grey/Black: Right(-) speaker
This appears to be a 2 channel unit so use one pair.
Old Jun 27, 2010 | 12:26 AM
tragichero's Avatar
My Other Ride is a Huey
I had a similar one that had two channels as well, I just connected the one + from the stock sub to both + on the LOC, same with the -. Works like a champ.
Old Jun 27, 2010 | 07:35 AM
Thanks guys. Man I suck at searching. I googled the sni 35 but didn't find the mani's website. Never thought of checking there. I couldn't tell what wires were paired with what. Thanks again.
Old Jun 28, 2010 | 10:00 AM
Thanks guys. I paired the wires incorrectly. Got it working now....Just need to play with the gain settings.
Dec 7, 2020 05:39 PM
BoricuaTL
Apr 8, 2016 01:08 PM
Sep 17, 2015 10:16 AM
d.lim
Sep 15, 2015 08:54 PM
alan_rich
Sep 7, 2015 11:08 PM
