Need help removing rear sub/speaker deck!
Hi everyone,
Im in the process of changing out the rear speakers and sub but happen to got stuck after removing the rear bottom+back seat.
I cant seem to be able to pull/remove the deck dont know if i need to touch the side curtain air bag or not which im a little reluctant to do.
if someone can help it would be appreciated! directions or pics would be killer
thank you folks,
Envy-
thank you folks,
Envy-
thank you' cam on anh ban
I was worried about pulling it off just cause it said airbag.. what a shame Ive been sitting here for an 1hr *knock on head
so remove the side pillar covering the airbags rights quang?
Get a flathead under the clip and the middle pulls out of the rear C-pillar trim then it comes off. Has about 5 clips. Then you can pull up on the rear shelf and it will come up as soon as you get all the clips undone
mada51589
Jan 9, 2025 04:40 PM
