Need help !!!!!!!!!!!!!!!!!!!
Old Mar 12, 2015 | 02:13 PM
kevins2004tl's Avatar
i have a 2004 acura tl and every time i put radio fuse it pops.what could cause this thanks for the help.
Old Mar 13, 2015 | 11:14 AM
any info
Old Mar 13, 2015 | 12:20 PM
polobunny's Avatar
Registered Bunny
Bad wiring?
Old Mar 13, 2015 | 03:28 PM
has factory radio i unplugged amp accy plug still pops
Old Mar 13, 2015 | 04:01 PM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
Are you replacing with the correct size fuse?
Old Mar 13, 2015 | 08:37 PM
Yes same fuse even tried 20 amp fuse still pop
Old Mar 13, 2015 | 09:27 PM
Will Y.'s Avatar
Registered but harmless
Any remote start, aftermarket alarm or other aftermarket stuff on the car?
Welcome to AZ, BTW.
Old Mar 14, 2015 | 09:54 AM
i just bought car all i see is a power wire for amp and remote wire thats cut by left foot rest.
Old Mar 14, 2015 | 08:53 PM
QuickTL07's Avatar
looks like some modifications have been done to your oem radio, did you take anything apart or look where the power wire is coming from? also look by your oem amp to see if there is any wires that are cut, something must be grounding its self off.. if you could take some pics of the wire, that might help...
I know you may not want to do this, but pull your oem radio out, and unplug it from the car, put the fuse back in and see what it does. you also want to check the rear cables to make sure everything is in place, and no-one has been massing with it.
Old Mar 14, 2015 | 09:00 PM
That's exactly what I did took radio put fuse did not pop a nickel fell out radio plugged in now works thanks for input guys
