Need help
Need help
Hi guys, Im looking for the Speed Detection Circuit Lead on my 06 TL, please let me know if you know the location of it, better if you have picture of the location. Thank you
Originally Posted by Crook
Which "Speed Detection Circuit Lead", the one from the transmission to the speedometer, VSA or cruise control?
I can't tell you where the wire is in the dash because I don't have the Electrical Service Manual but you can find it on top of the transmission housing under the hood. On an automatic tranny, you can stand at the left fender and lean over the under hood fuse box. Look directly under the fuse box at the top of the transmission, you'll see a small harness plugged into the speed sensor mounted in the top of the transmission. The plug has three wires wrapped in and black plastic sleeve. The blue wire is the one you are looking for I believe. I think blue is in the middle between a yellow/red and green/white wire. Sorry I can't tell you where to find this signal inside of the car.
