NavTool Power Question
Old Jun 1, 2009 | 05:07 AM
whizzups's Avatar
This is a probably dumb question, but I just want to see if there is any reason my thought process won't work here.
I ordered the NavTool unit and will be hooking it up to my iPod Video and/or Touch. I know most people run the power cable to the fuse box and ground in the trunk. My wiring skills are at about a 4 year old level, so I thought of a potential easier solution. I ordered a dual Jolt charger that has two usb ports to run power from. One will be used to power the docked iPod. I am thinking of using the other port to power the NavTool.
I am already running the video cable and toggle switch lines to the center console and would have to run power to the front anyway, so this would allow me to bundle all of the cables and run everything together to the same spot. The lower cubby in the center console armrest is going to be my convergence area so I can plug in my portable DVD player if I want to watch a DVD. A USB cable has 4 wires (red, black, green, white) 2 for data and 2 for power. By connecting the red and black leads from the USB cable to the ground and power from the NavTool it becomes a homemade USB power cable.
I guess my two questions with this are:
1. Is this too far from the unit (mounted by the DVD-Rom Drive) to run the ground?
2. Is there anything else I am missing in my logic that makes this a bad idea?
I am definitely new to all of this, so any advice from experienced installers is much appreciated.
Thanks!
Chris
Old Jun 1, 2009 | 06:42 AM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
I think this could work.
Old Jan 12, 2011 | 02:34 AM
Dom!nO's Avatar
Thanks!
Chris
did this ever work im about to attempt the install
Yikes
May 3, 2021 04:29 PM
VA2000TL
Oct 2, 2015 08:26 AM
Sep 17, 2015 09:01 PM
MayorMcCheese
Sep 14, 2015 11:23 PM
datadr
Sep 12, 2015 09:12 PM
