Navi Power Source?
Old Jul 15, 2006 | 08:09 PM
Laxplaya11385's Avatar
Navi Power Source?
Does anyone know which wire is the power source for the navigation unit in the trunk?
Old Jul 15, 2006 | 11:50 PM
datmrman's Avatar
I don't know, but I hope you're not planning to tap into it to power Dom's unit. Dom recommends that you do not. I tapped the cig adapter/power outlet of the center console. Here are the instructions from my install.
If you still insist, PM gt1. I think he tapped into the navigation power source.
Old Jul 16, 2006 | 12:23 AM
I actually dont' have Dom's unit. I bought an AVElectronics Unit (used), and the install that I found on the forum has the guy tapping into the Navi power source.
Old Jul 16, 2006 | 12:55 AM
datmrman's Avatar
Well, if you need a switched 12V source, that cig adapter/power outlet of the center console will do it. Power will only be available when the car is on.
If you don't want to tap into wires, use a mini add-a-circuit and connect it to fuse #32 in the fuse box on driver's side. You'll just need to run wires from the fuse box to the trunk. That is still switched 12V.
If 12V is what you need, I would recommend you to do one of the above methods rather than using the navi power source.
Jul 16, 2017 07:33 AM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
Cgannotti
Sep 25, 2015 05:04 PM
