Navi Log File Question
Old Sep 13, 2011 | 06:52 PM
cinobyte's Avatar
So I know the system keeps some log files because I can go back a few days and see what the trip computer stored. any idea how many log files it stores? do you need to del them?
The reason for my question.
navi was acting up IE going from dvd to fm was really lagging even on the radio if I changed stations it would change eventually but the display took even longer to update than the station change did.
I decided today just to reset whole system I figured I had one of two problems. first being a short with soon to be failing system. Second the ISimple had screwed up.
Resetting the system resolved the problem for now which makes me think log files could have been the issue.
06 with all the normal navi hack files. (which are gone after the system reset)
TIA
Old Sep 13, 2011 | 08:55 PM
cinobyte's Avatar
None of you TL guru's got any comments at all?
Old Sep 14, 2011 | 10:16 PM
cinobyte's Avatar
I wanted to update in case some one stumbles on the post.
I think the isimple adapter is causing the problem.
I made the assumption the system was getting loaded with logs which would decrease the (for lack of a better term) ram of the unit.
Type S Zero
Feb 17, 2016 02:37 PM
datadr
Sep 12, 2015 09:12 PM
Vejey Gandier
Sep 12, 2015 08:59 PM
gnuts
Sep 11, 2015 10:07 AM
