NAVI display brightness - day/night toggle?
Old 01-11-2012, 10:18 AM
2021 RDX A SPEC
Acura604's Avatar
The RDX has this button below the navi screen that lets you immediately toggle
day/night/OFF on the Navi display....not sure if the TL has it other than
going into the setup function and choosing the option.
Is there a shortcut button to do this?
Old 01-11-2012, 10:23 AM
Received 16,265 Likes on 11,974 Posts
yes, on the left hand side of the steering wheel there are three buttons of display.
a toggle button and a lighter and darker button
Old 01-12-2012, 11:02 AM
Keep Right Except to Pass
1995hoo's Avatar
The button to which "justnspace" refers is labelled "MAX." It toggles the dashboard lights to and from max brightness and is something you'd use in situations like driving in the rain or on a two-lane road or when the sun is low on the horizon where your headlights have to be on during the day. If your Navi is set to "Auto" display mode, meaning it switches to night mode when you turn on the headlights, using the "MAX" toggle switch will switch the Navi back to daylight mode (and, of course, vice versa if you later need to switch it back).
The "MAX" button will not, however, turn off the Navi display. You can use the voice commands to do that, though, if you don't want to click through the menus.
Old 01-12-2012, 11:59 AM
2021 RDX A SPEC
Acura604's Avatar
excellent..forgot about the voice commands! Thanks!!
Old 01-12-2012, 05:31 PM
vp55's Avatar
Does keeping your Navi on max do any harm? Do most of you guys keep yours on max, or the level below it?
I usually keep it on max but wasn't sure if it will decrease the bulb life.
Old 01-12-2012, 06:01 PM
6-SPEED LOVER
ABP_04TL's Avatar
I keep it max, then once night hit it dims
ITSJESTER
17
12-06-2018 02:29 AM
08_UA7_Gr33k
02-11-2016 02:17 PM
lanechanger
10-13-2015 10:56 AM
Cgannotti
09-25-2015 05:04 PM
eastcoastguy
09-23-2015 06:29 AM
Quick Reply: NAVI display brightness - day/night toggle?
