Nav Gone... NavToTV Intermitant - HELP
My car was in the shop for collision work (some idiot hit my right rear door). When I got it back the Nav won't work and my NavtoTV (for my PS2) works every once and a while on either interupt switch position. Worked fine before I took it in. Not sure what to try. Any thoughts?
Have you rentered the Navigation System code? There are separate codes for both the radio and the Navi which must be entered for each system to work if the battery is disconnected (which the body shop probably did as a matter of course while working on the door panel). Both radio and Navi codes are on a cardboard card that comes with the manuals and extra keys, which are hopefully in your home somewhere.
UPDATE!!! It's fixed.
Either someone wanted to see how I installed my PS2 or the strangest coincidence happened. One of the wires broke off the back of the NavtoTV bypass switch... which is no where near the work that they did. Odd.
Resoldered them and I'm back in business.
Thanks for the help.
Jul 16, 2017 07:33 AM
navtool.com
31
Nov 16, 2015 08:30 PM
