My '04 TL CarPC (Long with ALOT of pics, no 56k)
Old 04-27-2008, 06:02 PM
  #41
ITL
I do my own work.
ITL's Avatar
Originally Posted by nitropwd
oh naww, i was actually going to hunt for a wrecked TL to find the extra parts that i needed.
did you ever find any extra connectors?
Old 04-28-2008, 02:08 AM
  #42
Honda Noob
nitropwd's Avatar
hey ITL, no i didnt. i'm still looking. i have been even thinking of driving down your way in an attempt to get some work done.
Old 09-15-2008, 07:49 PM
  #43
Do you have the ODB-II diagnostics running? I have an 07 TL-S and want to install this but not sure if the ODB works for Centrafuse
Old 09-19-2008, 05:30 PM
  #44
SLAYER6669's Avatar
I never did install any OBD on this PC and I don't have any plans to install one. I had it on my Grand Prix but I did not use Centrafuse for that since the software didnt include OBD back then. I used an OBD cable/software from OBD-2.com for that one. It's not the most visually pleasing software but it worked. I still have my OBD-2 cable but it only works with the software provided with it.
Old 09-21-2008, 01:14 AM
  #45
ezland00's Avatar
can someone tell me how to mount the stock LCD( non-nav) to the lower console?
Old 09-22-2008, 09:05 PM
  #46
SLAYER6669's Avatar
I'm not sure how everyone else did it because it took me a while to come up with an idea. When I was fitting it below the radio, I couldn't figure out how everyone put it down there but just cutting notches in the bottom corners of the board. I cut some off and it still didnt fit, so I wasn't comfortable trimming more. I stopped cutting the board and cut slits in the AC duct that runs to the back of the center console instead since I don't really care about those vents anyway. In the end barely any air leaks out of the slits. The bottom of the LCD just rests inside the slits.
For the top, I took 2 small "L" brackets, I had to shave the corners a little to get them to not touch anything, then I screwed one side of the L to one of the holes which held the compartments to the shift plate and zip tied the other side of the L to the hole in the top corners of the board. It's pretty loose in there but the screen never moves. In short, I rigged it!
mugen_kid
11-13-2015 10:38 PM
pozebly
09-23-2015 07:30 AM
cacheflowe
09-14-2015 10:35 AM
darksky
09-05-2015 03:11 AM
Quick Reply: My '04 TL CarPC (Long with ALOT of pics, no 56k)
