My '04 TL CarPC (Long with ALOT of pics, no 56k)
Hey all, I figured I would finally post my CarPC install in my '04 TL. This is a non navi car as you can tell from the clock/stock lcd displays. In my first attempt I did not like the way the bezel looked after I cut/sanded/painted it so I found a cheap cracked Navi Screen on Ebay and used that since no cutting on the outside is necessary so it looks perfect.
I did the original install in September and about a month ago I pulled the whole dash apart again and swapped out the bezels and I also had to redo the stock LCD on the bottom beacuse it didn't look very good. At the moment the Navi buttons are just kinda "there", they do nothing, they don't even light up (if anyone know’s how I can make them light, I'm all ears I couldn’t find the wiring schematic for the connector on those buttons).
I decided to place the PC in the glove box beacuse I don't like running all the PC wires to the trunk and I just didn't want the PC taking up any trunk space. Here we go
PC/Hardware/Prices:
Jetway VIA C7 1.5GHz Mini-ITX Motherboard ($230)
M2-ATX 160 Watt DC-DC Power Supply (included with MB)
Kingston 1GB PC4200 CL4 240 PIN DIMM Memory ($41)
Maxtor 120GB 7200RPM IDE Hard Drive (Already had)
USGlobalSat BU-353 GPS Receiver ($53.95)
ATI All-in-Wonder Media Remote ($20)
Xenarc 700TSV 7" LCD ($295 used)
TL Navi Bezel ($35)
Software:
Windows XP Professional (already had)
Centrafuse Frontend ($124)
iGuidance Navigation Software (already had)
RWKeymaster/Factory for Remote (free)
Total Cost/To Do:
Installation: Free (DIY)
Total Cost: $798.95 + Misc Wiring/Cables/Supplies (not bad huh?)
Left to buy/do: Reverse Camera, Microphone for voice control, Possibly Internet Access.
Pictures:
Note: I did not take any new pics during the process of swapping in the navi bezel and redoing my non navi stock screen, so I will just include the pics of the orginal install with the non nav bezel for reference.
Dash/Console/Glove Box all disassembled, the two green connectors sitting on top of the head unit get cut off and extended to where the compartments were
![](http://www.thirdgenfbodies.com/images/carpc/gutted.jpg)
HVAC control wires extended
![](http://www.thirdgenfbodies.com/images/carpc/hvacextended.jpg)
Connectors for stock LCD extended
![](http://www.thirdgenfbodies.com/images/carpc/lcdwiresextended.jpg)
Bezel Cut/Sanded/Painted, Xenarc Inside, HVAC buttons reattached
![](http://www.thirdgenfbodies.com/images/carpc/nonnavbezel.jpg)
![](http://www.thirdgenfbodies.com/images/carpc/nonnavbezelback.jpg)
LCD Installed, Stock LCD placed in compartment area (old pic from first install)
![](http://www.thirdgenfbodies.com/images/carpc/lcdinplace.jpg)
It's alive! Starting the car after first plugging in the screen was nerve racking after trimming the corners of the board off and all the wiring but all was well
![](http://www.thirdgenfbodies.com/images/carpc/stockscreenrelocated.jpg)
A sheet of plexiglass cut to fit where the compartments used to be, and painted to cover the LCD board. This was completely remade on the second install.
![](http://www.thirdgenfbodies.com/images/carpc/plexicut.jpg)
The plexiglass that was in the stock bezel, cut down and attached to the LCD board
![](http://www.thirdgenfbodies.com/images/carpc/stockscreenplexi.jpg)
All the wires for the PC running through a hole I dremeled in the housing behind the glove box (now you can see why I prefer not to run all of these wires to the trunk)
![](http://www.thirdgenfbodies.com/images/carpc/wires.jpg)
Here is the Motherboard and M2-ATX Power Supply mounted to a piece of plexiglass with motherboard standoffs..
![](http://www.thirdgenfbodies.com/images/carpc/carpc.jpg)
The PC installed. The glove box is basically the "case" for the PC. It JUST fits as you can see. I used a regular IDE hard drive I had in my GP GTP CarPC since I already had it. I eventually might replace this with a Laptop HD so it’s not so tight.
![](http://www.thirdgenfbodies.com/images/carpc/carpcinstalled.jpg)
Here is two USB cables I ran to the center console (other one is my cell phone charger). I can also plug in a 7port USB hub into one of these if I need extra USB plugs. I just connect my 8gb USB flash drive to one of these connectors and I can play music directly off of it and/or add it to the PC Library.
![](http://www.thirdgenfbodies.com/images/carpc/usbcables.jpg)
USB cables coming in, the red switch (top left of pic) is the PC on/off switch if I need to manually turn it on/off.
![](http://www.thirdgenfbodies.com/images/carpc/console.jpg)
GPS Receiver. Again, I didn't wanna take the rest of the car apart to run one measly wire to the rear deck just to hide the GPS receiver, plus these receivers can be fussy with tint. This was the best option for a good view of the sky, especially since the PC was right there in the glove box and I didn't even have to extend it's USB wire at all.
![](http://www.thirdgenfbodies.com/images/carpc/gps.jpg)
The Broken navi screen I got off ebay
![](http://www.thirdgenfbodies.com/images/carpc/navibezel.jpg)
Full Dash Shot
![](http://www.thirdgenfbodies.com/images/carpc/interior.jpg)
New pics of the stock screen after my redo. Looks a bit better.
![](http://www.thirdgenfbodies.com/images/carpc/stockscreen.jpg)
Navi Bezel Installed
![](http://www.thirdgenfbodies.com/images/carpc/lcd.jpg)
![](http://www.thirdgenfbodies.com/images/carpc/lcd2.jpg)
ATI Remote Wonder Media remote.. I just keep this on the seat next to me and use it to control centrafuse. With RWKeymaster I can set just about any button on the remote to press any keypress. Then I just set the hotkeys in Centrafuse. Easier than holding my arm up to hit the next track button 15-20 times. That hurts after a while![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
![](http://www.thirdgenfbodies.com/images/carpc/atiremotewonder.jpg)
![](http://www.thirdgenfbodies.com/images/carpc/dash.jpg)
![](http://www.thirdgenfbodies.com/images/carpc/dashnight.jpg)
Windows XP Boot screen with a modified BMP image I got from mp3car.
![](http://www.thirdgenfbodies.com/images/carpc/windowsboot.jpg)
![](http://www.thirdgenfbodies.com/images/carpc/windowswelcome.jpg)
Desktop, temporary pic until I get a few more mods done and get some nice photos of my car
![](http://www.thirdgenfbodies.com/images/carpc/desktop.jpg)
Centrafuse Pics/Skins:
(Sorry, these are very grainy, I think it’s because of the batteries being almost dead in my camera, and some are darker night skins with pics taken during the day so it’s hard to see, I will replace the images later on)
Centrafuse start screen with an image I made with the Acura NSX Font.
![](http://www.thirdgenfbodies.com/images/carpc/centrafuseboot.jpg)
Default Onyx Day skin:
![](http://www.thirdgenfbodies.com/images/carpc/onyxmenu.jpg)
![](http://www.thirdgenfbodies.com/images/carpc/onyxmedia.jpg)
![](http://www.thirdgenfbodies.com/images/carpc/onyxlibrary.jpg)
![](http://www.thirdgenfbodies.com/images/carpc/onyxlibraryalbums.jpg)
![](http://www.thirdgenfbodies.com/images/carpc/onyxfullscreenart.jpg)
![](http://www.thirdgenfbodies.com/images/carpc/onyxmixer.jpg)
![](http://www.thirdgenfbodies.com/images/carpc/onyxeq.jpg)
![](http://www.thirdgenfbodies.com/images/carpc/onyxlevels.jpg)
![](http://www.thirdgenfbodies.com/images/carpc/onyxig.jpg)
![](http://www.thirdgenfbodies.com/images/carpc/onyxigfull3d.jpg)
![](http://www.thirdgenfbodies.com/images/carpc/auraigmenu.jpg)
![](http://www.thirdgenfbodies.com/images/carpc/auraigdest.jpg)
![](http://www.thirdgenfbodies.com/images/carpc/onyxcalc.jpg)
Default Onyx Night skin:
![](http://www.thirdgenfbodies.com/images/carpc/onyxnightmenu.jpg)
![](http://www.thirdgenfbodies.com/images/carpc/onyxnightmedia.jpg)
![](http://www.thirdgenfbodies.com/images/carpc/onyxnightvisual.jpg)
![](http://www.thirdgenfbodies.com/images/carpc/onyxnightig.jpg)
Hope you all enjoy, this thread just took me way to long to write
Pics of more skins I have in the car here: Click here!
PC/Hardware/Prices:
TL Navi Bezel ($35)
Software:
Total Cost/To Do:
Pictures:
Full Dash Shot
![Coffee](https://acurazine.com/forums/images/smilies/coffee.gif)
Turd Polisher
HOT. I basically just looked at what it took to make the CarPuter / costs / pictures ... but .. how long did this project take?
Turd Polisher
Originally Posted by SLAYER6669
I took my time with it, the actual install process took about 25-30 hours or so over 3 days, give or take. That includes many breaks for food etc. and some trips to the store . I just bought the car in May so it was my first time taking the car apart and putting it back together. The second time when I went back in I took it apart and put it back together in way less than half the time it took the first time.
Thats hotness! Pure hotness.
As for the navi buttons, you CAN make them work. I'm still looking around for a cheap navi screen and bezel to hook mine up, but we bought the OEM bezel for our 350Z and tapped it into the PC via a keyboard controller and now is fully functional.
I'm going to wait on "Saturated Fat" to see this thread. He'll fill you in.
Good stuff!
Collin
Good stuff!
Collin
very nice!!!! look better then mine. but aren't you worry about the mobo in the glove depotment getting to hot? it doest look like it have air flow through it..i suggest you cut anothe hole and add a fan to suck hot air out.
Good stuff!
Collin
Good stuff!
Collin
http://www.thirdgenfbodies.com/image...nconnector.jpg
Originally Posted by ezland00
can you use laptop instead? you can hide it under the seats
Originally Posted by KN_TL
Slayer,
I forgot to complement you on the great job on the install in my PM's.
Since you've done 4 other installs, I assume you've tried Roadrunner at one point. Can you list the differences and advantages of Centrafuge over RR?
Well this kinda sucks, the dash is going to have to come all apart yet again. Any time I hit a rough bump I get this plastic "snapping" sound from the Xenarc/Navi Bezel
It's wierd because I never got ANY noise with the non navi bezel. I guess I will have to put some kind of felt in between the two.
Also, on the inside of my plexi that covers the stock LCD I see streaks all of a sudden.
I cleaned it with Stoners Invisible Glass and held it up to light before installing and it was crystal clear.. Something in the air must have brought out the streaks.. Any suggestions on streak free plexiglass? I don't want to take it apart and clean it and end up with the same issue again. It never ends
![Yuck](https://acurazine.com/forums/images/smilies/yuck.gif)
Originally Posted by nitropwd
hey slayer, how is the xenarc actually attached to the back of the bezel? i have taken my dash just yet.
B A N N E D
Beautiful... i have a non navi and i want to make it into a navi or car-pc . Is there a whole kit to buy this ir anyweb site or know anyone that can sell them or a stock navi? get back at me yes or no - thank you and great job !!!
PC/Hardware/Prices:
TL Navi Bezel ($35)
Software:
Total Cost/To Do:
Pictures:
Full Dash Shot
PC/Hardware/Prices:
TL Navi Bezel ($35)
Software:
Total Cost/To Do:
Pictures:
Full Dash Shot
IMO a PC is better beacuse you can basically do whatever you want with it instead of just being limited to what the navi system lets you do. As for the CarPC, it's something that you have to really customize to your needs (DIY) in terms of picking out the hardware/software.. Have a visit at www.mp3car.com and all the info you need on installing a CarPC can be found on that forum. They do sell kits there in the store as well. There are also some members on here who will do installs (depending on your location) for a fee of course. Good Luck!
Originally Posted by DaddysOnehotAck
Your not technical??.........you sure you didn't graduate from MIT??.....lol, Good JOB!
![HaHa](https://acurazine.com/forums/images/smilies/haha.gif)
Slayer, how exactly did you extend the wires? Did you use use butt connectors or did you solder and use shrinktube? sorry for so many questions.
B A N N E D
I'm not sure much about where to get navi conversion parts from, I think most people check junkyards for parts or Ebay. If you are interested in going that route, search this forum there are a bunch of threads for non navi to navi conversions.
IMO a PC is better beacuse you can basically do whatever you want with it instead of just being limited to what the navi system lets you do. As for the CarPC, it's something that you have to really customize to your needs (DIY) in terms of picking out the hardware/software.. Have a visit at www.mp3car.com and all the info you need on installing a CarPC can be found on that forum. They do sell kits there in the store as well. There are also some members on here who will do installs (depending on your location) for a fee of course. Good Luck!![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
Originally Posted by ITL
your install looks very familiar
awesome setup, man!
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
Honda Noob
damnit, if only i could find someone to extend my harnesses, i'm paranoid to try it. and the sad part is i have ALL the parts ready to go.....complete pc, Navi Bezel, Xenarc, EVERYTHING!!!
This is beyond depressing.
I also dont have a garage to work in. lol
I do my own work.
There's nothing very difficult about extending the harnesses, it's just terribly time consuming. I've done this twice, and each time has taken me about 4.5hrs, which also includes fabricating the plexi for the non-navi lcd below. This is not something you ever want to try to troubleshoot, so it's important to make sure it's done right the first time. I take my time here, and label (numbered) all wires during prep. The actual soldering goes pretty quick, it's the prep work that takes so long.
I finally found some pics to show how good the wiring came out. For the non-navi, two harnesses have to be soldered in the car (left pic). The other two harnesses (right pic) are a bit easier, since the HVAC controls can be removed from the car while extending the harnesses.
Here are a couple of pics of my extended harnesses:
![](http://farm3.static.flickr.com/2005/2328215489_e242f26b30_o.jpg)
![](http://farm3.static.flickr.com/2077/2329040536_8be2532339.jpg?v=0)
I do my own work.
Yeah I imagine it does look a little familar
Though I just threw the PC in the glove box instead of making nicer cases like you did. If I didn't see your install I probably would've never thought of it. Who needs a glove box anyway! A special thanks to you for answering my questions before I began the actual install process too! ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
IMHO, the glovebox is the most elegant location for the carpc. Less wiring makes for less potential interference/noise. I didn't use my glovebox for anything anyway...though with my latest case, I even have some storage space in there, believe it or not! Glad I could help. This is such an involved project, as anyone that's already done it can obviously tell you...It makes things 10x easier to know what you're getting into, or at least have someone to guide/advise you. All I had at the time was moahdib. Now, there are quite a few guys that have done these installs, which makes everything better for everyone.
As for the glove box, it's like the perfect spot. It's out of sight for theives, out of the way, less wires, and you can even lock the glove box for whatever that's worth. Doesn't get much better than that!
Nice pics too, your wiring is so much neater than mine and I can tell that even through the wire loom
Honda Noob
hey nitro, where are you located? Would you be willing to drive to Atlanta?
ITL, I'm Bloomington, MN.....a 'burb right outside of minneapolis. believe me i'm really thinking about coming down there to get this done. but that would be a LONG drive. Havent gone that distance since my days in the Marines Corps.
would be be possible to make an extention for the harness by using the connector from the back of a broken navi screen? if so i would more than happy to send you what i have
I do my own work.
would be be possible to make an extention for the harness by using the connector from the back of a broken navi screen? if so i would more than happy to send you what i have ![Wish](https://acurazine.com/forums/images/smilies/wish.gif)
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
Honda Noob
It wouldn't be possible with just one connector...you'd need a connector for the other end of the extension cable. Even if you had both, there are still the other harnesses in the car. I doubt you really want to pull the upper dash/airbags etc just to ship a harness ![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
This is amazing - nice work! Of course, you know what you started...now I'm gonna have to start doing some reading up on all of this. I just put a subwoofer in (uncald4 built it from the vendor forum) and I built a custom amp rack - this was after months of saying I wasn't going to get back into all of this again. After seeing this, I'm sure my car will be right back to where I left the CL when I bought my TL
haha
