Music
Old Jul 13, 2008 | 11:48 AM
sderiko's Avatar
4th Gear
Music
Im almost done payin for my 04' TL(navi). I want to put some better quality sounds in my whip. Dont want to lose my Navi. I tried back in 05', but they was not ready. Anybody know where to start?
Old Jul 13, 2008 | 01:28 PM
csmeance's Avatar
Hi and welcome to the forums
to answer you question, upgrading the audio in the TL isn't that hard really, as long as you keep the factory head unit. Here are two options for the best sound out of the factory head unit, the first one costs less, but won't give you any tuning options for the audio.
1. Factory Radio -> factory Amp-> Tap wires after amp, but before speakers -> send signal to aftermarket AMP (Line out converter may be needed to reduce voltage) -> aftermarket speakers and sub
2. Factory Radio-> Factory Amp -> Tap wires after amp, but before speakers-> to Rocksford Fosgate 3.sixty.2 audio proccessor (or any one for that matter) -> aftermarket amps -> aftermarket speakers.
Old Jul 13, 2008 | 04:47 PM
sderiko's Avatar
4th Gear
Thanks for getting back at me. But can i run a factory amp. to a amp. tube and still sound ok . Dont want to spend too much. If I dont hv to!!!!!
Old Jul 13, 2008 | 05:12 PM
csmeance's Avatar
Quite can't understand what you mean, but I think you mean that can I run the factory amp, then straight to the aftermaket?
If that's it, then yes, but only if you aftermarket amp has HIGH VOLTAGE inputs. I know a few JL amps have it.
Old Jul 13, 2008 | 05:16 PM
Stew4HD's Avatar
I think he means a tube type sub box??? I am trying to cypher that too.
Old Jul 13, 2008 | 06:09 PM
sderiko's Avatar
4th Gear
Yeah! Tube type sub box. any in site on that project
Old Jul 13, 2008 | 06:10 PM
sderiko's Avatar
4th Gear
List JL products
Old Jul 13, 2008 | 07:05 PM
csmeance's Avatar
List JL products
All JL products have it, I checked their site. The feature is called Differential Balanced Inputs for their company. If you look in the picture below, you can see the switch for Low/High input.
I wouldn't just go with JL products, there are many companies out there with better quality amps and features.
Old Jul 13, 2008 | 07:09 PM
csmeance's Avatar
Well maybe, the stock sub is 40 watts a 2ohms, 20 watts at 4ohms. If you got a tube with a low enough sensitivity, then it would work. But most likely you won't find a tube like that and you will need an amp.
snorf
Nov 4, 2019 06:44 AM
SilverJ
1/2G MDX (2001-2013)
Sep 21, 2015 02:40 PM
rockyboy
Sep 21, 2015 10:47 AM
ja17
Sep 7, 2015 06:08 PM
