mounting a subwoofer in the trunk
Old Jun 10, 2010 | 01:06 PM
srm16's Avatar
I have to mount a subwoofer in the trunk of my 07 TL type S with some mounting straps. Therefore, I need to screw 4 screws to the trunk floor. I was debating on mounting it directly behind the backseat on the drivers side. Is this a safe spot? Does anyone know if there are any wires, fuel lines, gas tank or anything I may damage in this location?
Thank you!
Old Jun 10, 2010 | 02:11 PM
cumminsfan404's Avatar
i used some heavy duty wide double sided tape. works awesome! hasnt flipped or moved since
Old Jun 10, 2010 | 04:07 PM
BlacuraTL-S's Avatar
NBP REPRESENT
go to home depot and get the industrial velcro...4 dollar solution
Old Jun 17, 2010 | 02:17 PM
RjG2's Avatar
To tell you the truth I didnt want to drill my sub to the ground because it would limit my access to my spare. Instead I used the factory cargo net and stretched it across in front of the sub as if to create a wall . My sub has not moved since and it is not restricted from functioning properly.
08KBP_VA
Oct 22, 2019 01:55 PM
Jul 16, 2017 07:33 AM
kb1rl
Sep 30, 2015 10:17 AM
jmaxima03
Sep 27, 2015 10:22 AM
