Mounting depth in the front doors
Old Aug 22, 2008 | 08:21 AM
Color Me Rad's Avatar
3rd Gear
Will speakers with a 75 to 75.5 mm depth fit in the doors?
Will 14 or 23 mm tweeter depths fit in the stock location?
Old Aug 22, 2008 | 09:02 AM
rodneyc77's Avatar
Retired!!! ON TOP!!!
Yes.... there is alot of room in the door... roll down your window and remove the panel and speaker... then measure the room... you'll notice that the actual window doesn't even go down to where the speaker is... the speakers I have are more than 4 inches deep... and I'm only using a 1/2" MDF spacer... However, you will have to widen the existing speaker opening to fit MOST aftermarket speaker in there...
Yes... to the tweeter depth... what I would recommend you to do is surface mount your tweeter to the factory grill/cover... you'll get much better sound quality...
Good Luck
Old Aug 22, 2008 | 09:39 AM
Nick337's Avatar
what kind of speakers are you running in the door speakers that are more than 4 inches deep?
Old Aug 22, 2008 | 09:45 AM
rodneyc77's Avatar
Studio speakers...
Old Aug 22, 2008 | 09:46 AM
3rd Gear
trying to run hertz mlk 165 in the doors and hertz hi-energy coax in the rear deck.
Old Aug 22, 2008 | 09:51 AM
rodneyc77's Avatar
Hertz are great speakers... they are huge in Europe... but a trying to make a name for themselves here in the States...
Good Luck...
Old Aug 22, 2008 | 10:03 AM
3rd Gear
how much do you have to mangle the speaker housing to fit them in?
Old Aug 22, 2008 | 10:07 AM
rodneyc77's Avatar
it all depends on the speakers you're using... they might have the NEO magnets that are tiny... and no triming of the existing sheet metal is necessary...
The sheet metal on the door is thin... a dremel would do the job...
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
BKSleeper
Oct 7, 2015 10:20 AM
sockr1
Oct 1, 2015 01:31 AM
08 NBP TL
Sep 8, 2015 08:49 PM
