Motorola V505
Old Sep 22, 2004 | 02:26 PM
waymay1305's Avatar
Motorola V505
Has anyone tried this phone with the TL? Your thoughts, please? Any different from the V600?
Old Sep 22, 2004 | 03:05 PM
mobilezen's Avatar
The V500 series has been out for awhile in other markets other than the U.S. The V500 and V525 have been used in Asia and Europe for quite a bit. In any case, the HFL performance should be similiar if not the same as the V600 given they share functions in the triplets series. I had a V525 awhile back, awesome phone.
Old Sep 22, 2004 | 03:38 PM
waymay1305's Avatar
Yes, but is the V505 any better than the V600? Any different characteristics?
Old Sep 22, 2004 | 04:05 PM
mobilezen's Avatar
* It weighs .10 ounces less than the V600.
* It is a hair longer, taller, thicker...and when I mean a hair, it is truly a hair.
* The biggest advantage about the V600 is that it can do voice memo/dialing which I can't find on the V505.
I would go with the V505 being that its been out a little bit longer in the world so it is slightly more refined. On a different note, where in Irving are you located? I see a white TL on a daily basis on MacArthur all the way past 635. I also see an Anthracite and Black one once in awhile...must be a sign for me to get mine soon. cheers.
Old Sep 22, 2004 | 04:21 PM
waymay1305's Avatar
My TL is the Green Pearl. I live in the Towne Lake subdivision off 183 & Esters Rd.
Old Sep 24, 2004 | 11:58 AM
Does anyone here own this phone yet? Does it display complete HFL information (signal and battery strength?) with the TL. Any noted problems with the phone itself or compatibility with the TL?
Old Sep 25, 2004 | 06:46 PM
MARVE37's Avatar
Just testing one. Has only signal level and so far it works
Old Nov 16, 2004 | 05:40 PM
Parrothead's Avatar
How about caller ID? Does that work OK with the v505?
Old Nov 18, 2004 | 03:32 AM
wyricke's Avatar
The wife has one. Signal and caller id work, but no battery.
Old Nov 18, 2004 | 03:51 PM
db252's Avatar
Just got one.....Signal and caller id work like wyricke says but no battery which I don't care since mine always seems to be plugged in when in the car. The clarity is great for both ends. One friend didn't even know that I was on speaker. 1 Day down and happy.
Old Nov 19, 2004 | 01:27 PM
MARVE37's Avatar
Extra Ring
I have a little problem with my V505 perhaps someone can help.
When I receive a call in the car it answers as set "YOU HAVE AN INCOMMING CALL" however I also get a ring in the V505 phone, different than the ring set for out of the car use (Flare). I have listed my settings below. Perhaps you can tell me how yours is set which may eliminate the problem. I can't get an answer from ATT, Motorola or HFL. Perhaps you can assist. Not many folks with V505 yet. Other then this problem it works fine all but no battery indication.
Answer Options Ring Styles>loud
Open to Answer>ON
Calls> Flare
Text>Bells
Headset Voice mail>
Bells
Auto answer>OFF Alarms>Triads
Data Calls> Attention
Fax
Calls> Attention
Ringer IDS> ON
Volume>7
Reminders> OFF
Car Setting
Auto answer>OFF
Auto Hands Free>ON
ivegotthenav
Sep 11, 2015 07:51 PM
icy CL
Dec 17, 2003 10:40 AM
kevin79925
Oct 4, 2003 05:56 AM
synth19
Jun 20, 2003 11:41 PM
