MICU Replacement
Old 03-03-2018 | 03:33 PM
cipher9878's Avatar
MICU Replacement
how hard is it to replace an MICU? Mines is broken as my interior lights don't go on anymore after I unlock the car with the remote. Everything else works fine but I'm just wondering. Because I miss this feature as I have puddle lights and they work amazing.
Old 03-03-2018 | 03:59 PM
restron's Avatar
BANNED
It all depends if your are handy or not
Old 03-03-2018 | 05:24 PM
cipher9878's Avatar
very handy, I've removed the amp and replaced it with ones under my seat, took my nav out and installed tablet, many many more modifications.
Old 03-04-2018 | 12:05 AM
guitarplayer16's Avatar
Originally Posted by Thomasv
Update:
Replaced the fuse assembly!
My door locking issue is now resolved. It locks and unlocks correctly!
The job of replacing it was a pain in the ass but doable. I basically removed the kick panel and the cover under the steering wheel. After that I started disconnecting all the connections on the front of the fuse assembly, 2 on the side, and then I unbolted the top and bottom bolt. I was able to pull the fuse assembly out just enough to see the 8 connectors on the backside. Took those off and reversed process for installation. Gotta take your time doing this...only took me 2 hours and the book states its 3.5 hours. Im sure this is so the dealership can rip you off nicely. Anyway, my parasitic draw issue is still present. I just read a thread on HFL issues so I'm recharging my battery and will see if disconnecting the HFL will fix that issue.
Good luck!
Old 03-05-2018 | 08:54 PM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
MICU was a pain in the ass to replace. Taking out all the plugs from the back was not easy. Good luck!
Old 03-24-2018 | 10:56 PM
cipher9878's Avatar
Good luck!
what do you think the issue might be? The unlock and lock lights don't work anymore but the interior lights work when I press them on and off. Nothing else seems to be affected besides the unlock and lock lights but I had puddle lights and I was driving in the rain and they started to go on and off by themselves so I disconnected them and the function ceased to exist after this smh.
Old 03-29-2018 | 09:45 AM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
Fuse?
Old 04-02-2018 | 01:48 PM
cipher9878's Avatar
Fuse?
checked all fused and they're good. Which fuse do you think would be bad?
Old 10-26-2024 | 09:27 PM
kplob's Avatar
8th Gear
Hi did you find a solution for the parasitic draw?
07-09-2013 05:38 PM
269683
07-03-2013 01:47 PM
msk12
09-11-2010 04:30 PM
nvdave
03-11-2007 12:48 AM
dansmith2004
12-15-2006 03:01 AM
Quick Reply: MICU Replacement
