low hissing problem
Old Feb 12, 2010 | 11:34 PM
tl2slow's Avatar
Bored at work
low hissing problem
whats up guys....quick question....i did my system a few months back and ive been getting a low hissing noise when the volume is at 0.....i got a rf 360 wired after the stock amp going in 2 rf amp....when i switch the 360 into aux mode the noise goes away...did i have to wire the 360 before the stock amp???? beside the little noise the system sounds great..there is no hiss at all when i put up the volume....also when i go pass 18 or 20 on the volume i lose some bass output...is that the stock amp well.....please help me out...
Old Feb 14, 2010 | 10:26 PM
Nick337's Avatar
did you try to turn your gains down a bit?
Old Feb 14, 2010 | 10:32 PM
tl2slow's Avatar
Bored at work
on what...the amps or the 360????
Old Feb 18, 2010 | 10:12 PM
Nick337's Avatar
on the amps.
Old Mar 11, 2010 | 08:39 AM
Xsclusv's Avatar
sup i have a 360.2 and have the same issue its called floor noise or white noise cant seem to get rid of it and my factory amp is totally removed from car so its either coming from factory headunit or rockford unit... whats ur conclusion?
Old Mar 11, 2010 | 01:08 PM
tl2slow's Avatar
Bored at work
yup i got it fix.....it was the car...so i sold it....
Old Mar 13, 2010 | 12:59 AM
Rabbot's Avatar
9th Gear
usually low hissing noises just come from the RCA's you're using. anything from low quality RCA's, low voltage signal in RCA's and wire placement can make that noise. If you were using the factory head unit, then more than likely you were using an RCA converter which just hooks up to your speaker wires creating an RCA signal or the one that comes with the amp. It wont be a perfect connection and signal will not be perfect so you can expect that low hiss.
Higher quality parts and a new after market radio with high voltage RCA outputs are usually the best solution.
Old Mar 13, 2010 | 08:15 PM
smarty666's Avatar
I am having this in my OEM ELS system in my 08 Base TL! I also noticed the hissing got worse as the really cold weather of the winter came on; it is the worse at cold start when the audio first turns when you don't hear anything and then when the XM comes on you don't hear the hiss over the radio playing; it gets a little bit better when the car warms up but you can still hear it a tiny bit often on between songs on the XM!
brought it into the Acura dealer a few months ago and basically told me that its a by-product of the system and that cold weather does make it worse; should lessen as the spring and summer come! told me I'll just have to live with it! its only really noticeable at cold start-up so I will live with it; only thing they said they could do is rip out and replace the entire audio system but I can't see doing that; dealership would probably make things worse by replacing it and right now the low hiss is the only issue; the rest of the audio, sound, etc works great throughout the car!
marcelft
Jul 10, 2018 06:17 PM
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
HeloDown
Sep 8, 2015 06:51 PM
