Lg Vx-8700
Old Apr 7, 2007 | 08:57 PM
RjS's Avatar
RjS
Lg Vx-8700
Just wanted to let you all know that the new LG VX-8700 works with the HFL. No issues to report thus far.
Old Apr 8, 2007 | 11:14 AM
george3761's Avatar
2007 TL Type-S
Question
Great to hear the phone works well with the TL. On a related note.. How do you like the phone? Who's your carrier? I have an older LG6000 w/Verizon and love it but it doesn't have BT. So i need to update.
Old Apr 8, 2007 | 01:48 PM
RjS's Avatar
RjS
So far I love the phone. Previously had the Razr and this phone is very solid. The 8700 is only available through Verizon.
Old Apr 8, 2007 | 05:35 PM
lembowski's Avatar
Trucki!!
And Alltel
Old Apr 10, 2007 | 01:10 AM
RjS's Avatar
RjS
You sure you're not referring to the 8600?
Old Apr 13, 2007 | 10:43 PM
Scuba629's Avatar
signal strength and battery displayed?
Old Apr 14, 2007 | 02:29 PM
RjS's Avatar
RjS
Yep
Old Apr 14, 2007 | 03:41 PM
ic kyle b's Avatar
After 4 days with the phone...
Signal strength is great. Call clarity is AMAZING... much better than the razr. Screen is great, camera is 10x better, keypad is nicer to use and the outside screen is very cool. Interface is much better than the rzr (rzr seemed laggy)
I text a lot (4000+ a month) and the inbox can only hold 50 messages, so I have to dump them frequently. On the razr it would just hold them until I dumped them all, the phone would just get slower. Battery life seems to be less than my razr but still adequate for how much I use my phone in a day.
Old Sep 27, 2007 | 04:56 PM
smenter's Avatar
6th Gear
I paired and when I made a call I hear 2 clicks, anyone have this happen or know why it does that?
Old Sep 27, 2007 | 07:31 PM
enormus's Avatar
Lt. Dangle
My Motorola E815 does the same thing . . .
Old Dec 29, 2007 | 11:36 AM
trancemission's Avatar
Regions Leader
Im starting to have issues with my 8700. Now when I get in the car it doesnt pair up.
My 8600 did the same shit. If I cycle the phone it will pair up fine. I was in the middle of a call the other day and the car just dropped the phone. said "bluetooth audio device has been disconnected"
Theres something up with this phone. any thoughts?
Old Dec 29, 2007 | 11:46 AM
Regions Leader
well maybe Ill FRU this one and try another. If this one doesnt work Ill take it to the dealer.
at least its been tested successfully.
http://www.handsfreelink.com/findaph...=106&year=2005
Old Nov 26, 2008 | 07:05 AM
Svp50's Avatar
I had this same problem. Verizon replaced the phone and now i can't pair at all. Any suggestions? Below is how i am pairing. Am i doing this right?
turn on BT on phone.
initiate pairing process on HFL
after saying the pairing key i hit the talk button and say ok
at that same moment i select add device on the phone and hit ok. after 3 secons later the phone says no devices found.
Old Nov 26, 2008 | 08:25 AM
6spdtl-s's Avatar
Nismo TL yo!
that is a lot of texting. Anyways, you can set the your inbox to auto-delete messages that exceed the limit. So if you have 50 in your inbox and you get a text, the phone will auto delete the oldest text in your in box.
Old Nov 26, 2008 | 06:10 PM
jaymo's Avatar
I have the same phone. First day I bring the car home I pair it with no problems, probalby make a dozen calls that night, signal bar showed, smooth sailing, etc. Fast forward a day... couldn't get it to auto pair. Reset phone, no dice. Tried to repair, couldnt even get that to work ...
y2kardell
Mar 27, 2009 07:20 AM
