LF Canadian TL'S with Navi hack
re
i have the following problem
datmrman says that there is 9 bin files but i only have 6 Bin files and 2 bin files starting by the letters zzz10,zzz101.
i need some help here
Next set of questions:
What car is this for and what version DVD?
Based on the newest guide from kennyc, it seems like you only need 2 BIN files: the loader BIN file and the BIN file containing the splash/trip computer/OK hack.
Do you know which BIN file your navigation is using?
If not, follow these instructions:
If you know that BIN file, then the only other requirement is the BN2HHMLD.BIN file or something similar.
ONE TIME SETUP: OBTAINING THE REQUIRED FILES
1. Put the keys in the car and turn it so the NAV turns on (dont need to start the engine). At the main screen of the navigation system (the disclaimer works), hold down the Map/Guide, Menu, and Cancel buttons for 5 seconds.
2. Hit the "Version" button on the touch screen.
3. Hold down the Menu button for 5 seconds.
4. Write down the filename next to the words "Loading
Filename" (mine is BNHH401A.BIN).
08_UA7_Gr33k
02-11-2016 02:17 PM
lanechanger
10-13-2015 10:56 AM
SUPRMN84
10-07-2015 09:46 PM
