LED dash conversion
Old Jan 23, 2016 | 10:41 AM
Luketic's Avatar
LED dash conversion
Can anyone link me to the DIY for this? Searched google a couple different times & can't seem to find it. The biggest thing I'm trying to find is what size do i need & how many? Thanks guys
Old Jan 23, 2016 | 12:44 PM
guitarplayer16's Avatar
They are T3 neo wedge, and depending on if you have nav or not, I'd say buying a pack of 30 should be safe with some to spare.
Old Jan 26, 2016 | 10:01 PM
Aaphree's Avatar
What I have done so far
Replacing the LEDs are different for the different parts of the dash. Currently I have replaced some of the lights with LEDs.
The trunk button, and VSA button are easy. Just pull the panel back and you can reach them. The mirror switch has the lights soldered to the circuit board, and so you would need to solder new ones in.
Heated Seats Buttons These require some work, but it's not hard. You need to remove the armrest unit, and slide the entire section back. A quick Google/YouTube search will show you how. Those are easy to access.
Sunroof Button/Interior Lights Button This is simple, you just pop the whole unit out (pry in between the black plastic and the trim around it). You will need to unplug some harnesses. You can replace the sunroof button and the interior lights button. The homelink are soldered in. Again, you'd have to solder new ones in.
Trip Computer/Dash Light Level Buttons For this you just pop out the trim around the gauges, it's all one piece. It's easier if you lower your steering wheel to the lowest level.
Hazard Lights Button This is easy, you just have to pop up the center vents trim. It is all one piece. Be careful because it is stubborn, and you can easily damage the plastic if you pry too hard.
That is all I have replaced. The remaining ones you can simply unplug are the steering wheel buttons and the buttons around the radio/navi screen. The buttons that are on the radio unit itself are all soldered on, as are all of the buttons on the doors. I don't have the time to bother with those, but maybe eventually since half of my lights are LEDs and the rest are the stock ones.
Sorry I don't have the link that shows the full install including soldering, but hope this helps some.
Old Jan 29, 2016 | 11:04 AM
Luketic's Avatar
Wow, definitely helped a ton! Any specific bulbs you bought or just off of eBay?
Old Jun 8, 2016 | 01:37 AM
workinprogress's Avatar
20x White 1206 SMD T3 Neo Wedge 1 LED Cluster Instrument Dash Lights New 8mm US | eBay
Old Oct 24, 2016 | 03:11 PM
alan_rich's Avatar
05 TL A-Spec
Big help thanks.... Are all these bulbs you listed (minus the ones requiring soldering) T3 Neo Wedge? Thanks.
Old Oct 24, 2016 | 04:22 PM
reading
dmtchung
2G RDX DIY & FAQ
17
Sep 13, 2017 08:52 PM
Eggs999bacon
Feb 3, 2016 03:40 PM
MonkeyTrucker
Jan 22, 2016 12:50 PM
GINTER
Jan 17, 2016 08:41 PM
