Kyocera 7135 with SDIO
Does somebody tried the Kyocera 7135 with bluetooth enable SDIO ? According to Kyocera customer service, the 7135 can be bluetooth enable by adding a small chip called SDIO.
Here is the original answer I got from Kyocera:
The 7135 is a non-Bluetooth enabled device, however there are add-on units
(SDIO ---SanDisk Secure Digital Memory Card) available on Kyocera web site
to enable 7135 to work as a blue tooth compatible device. You may buy SDIO
cards online from the following link:
http://store.kyocera-wireless.com
By using the SDIO card you can use 7135 with your Acura 2004 car as well.
Does somebody tried this combination with the TL system ? Does it work well ?
Thanks !
Thanks !
Thanks ![/QUOTE]
Did u ever get yours working? i've been checking the kyo forum
http://www.pdaphonehome.com
and those guys so no-
Thanks ![/QUOTE]
seaman
Aug 13, 2004 09:23 AM
