Just burnd a DVD-A with muliple groups...
Old Jun 30, 2005 | 02:53 PM
  #41
Dumont's Avatar
Team Anthracite Member
Here's the thread, thanks to Manbir to get Ulead to make a patch and also for hosting the file for downloading. Unfortunately Burn Now doesn't do multiple groups, all songs upto 99 depending on size, will be in a single group.
https://acurazine.com/forums/showthread.php?t=111785
Old Jul 1, 2005 | 09:46 AM
  #42
mp3car's Avatar
41 43 55 52 41 20 54 4C
This all seems very interesting, I'll have to try it, I was upset that the TL couldnt play MP3s, I always thought about the possibility of putting only 2Ch music on the DVD-A and seeing if it would play them, so you could fit 4 or 5 cds woirth on one dvd-a.... and now it looks like we can
Old Jul 1, 2005 | 11:49 AM
  #43
MeltdowN's Avatar
Even though you can fit the same amout of music (or more if you use DL) as an MP3 CD on a DVD-A, navigating is still a bitch. The ELS system does not display CD-Text or DVD-A track metadata. I like to categorize different bands into different DVD-A groups and having to hold down the SCAN and RPT button just to get to the next group is not too intuitive. Wish they'd fix these two issues; then, IMO, it would be a complete DVD-A system.
Old Jul 1, 2005 | 05:50 PM
  #44
markjrenna's Avatar
Can anyone recommend a burner to buy and maybe some to avoid. Thanks!
Old Jul 1, 2005 | 06:04 PM
  #45
chuck_r's Avatar
I have a Plextor, an LG, and a Sony (3 computers)...they all work. At this point, you might as well get one that supports double layer. The LG supports DVD-RAM as well...relevant if you get a set top dvd recorder that supports that format.
Old Jul 6, 2005 | 12:15 PM
  #46
Masta120's Avatar
Has anyone been able to get the song information from a DVD-A on the radio display?
I got about 90 tracks on a DVD-RW (changed to 16 bit). It would be more convenient to be able to see maybe the file name or tag info on the display....
Old Jul 6, 2005 | 12:39 PM
  #47
MeltdowN's Avatar
TL's player does not support CD-TEXT or DVD-A text, so basically, it cannot display any title or disc info. IMHO, one of the missing features with which, it would make the player perfect. The other feature I'd want, is the easy ability to navigate between DVD-A groups, without having to press 2 buttons simultaneously.
Old Jul 6, 2005 | 02:31 PM
  #48
markjrenna's Avatar
I agree with you 100%. I would also like to see maybe 24 XM presets and a way via steering wheel button to go through all XM channels. Then this would be one awesome system.
Old Sep 27, 2008 | 03:39 PM
  #49
6spdtl-s's Avatar
Nismo TL yo!
Originally Posted by jon1379
To create a DVD-A in WaveLab 5, follow the following basic steps...
1) Open WaveLab, go to File, New, DVD-Audio Project
2) Go to File again, New, Audio Montage. Leave the sample rate at 44100, and click OK
3) In the Montage window, click the tab labled 'Files'.
4) In the Montage Window, Files, click the open file folder to add .WAV files to your Montage.
(Yes, you must transfer your MP3's to WAV. I suggest Winamp's diskwriter output module)
5) Once they are all selected, and you click 'Open' you will be prompted to 'Line up on the current track' This is what you want to do, so click OK.
6) Now in the Audio Montage window, click the CD tab.
7) In the CD Montage window, click the 'DVD' button
8) Select 'Functions' Edit DVD-Audio options. Select 16 bit and click OK. Return to Functions and select DVD Wizard. Just click 'Apply in the window that opens.
9) In the main WaveLab window, select 'File' and 'Save' to save the Montage as a file on the desktop.
10) In the DVD-Audio project window, ( The first one you opened) Click the Green Plus sign to add the Montage you just created to your DVD.
11) in the DVD Project window, make sure your project will fit on a DVD - Less than 4.3 Gig.
12) Click the red disk to create. WaveLab will now write a disk image of you DVD onto your hard drive.
13) After the creation is complete, another window will open displaying the file structure of the DVD you've created. Click on the CD icon in that window to burn the data to a DVD.
14) pop the DVD in your TL and enjoy!
Wasn't that easy! :-)
I went through all these steps (i think) and when I put the dvd in it said 'format'. What could I be doing wrong?
Old Sep 28, 2008 | 10:42 AM
  #50
xen-cuts's Avatar
ROFLCOPTER!
Originally Posted by J RIDE 81
What's the sound quality comparing to regular CD's????
It cannot sound better than the original. There is only so much starting info and if you start at CD quality sound then that is the best you can have as output no matter what you change the songs to play on.
Old Sep 28, 2008 | 02:02 PM
  #51
Trew's Avatar
Are you using DVD-R or DVD-RW? You should be using -R.
xen-cuts. You're responding to a 4 year old post!
Old Sep 28, 2008 | 03:07 PM
  #52
6spdtl-s's Avatar
Nismo TL yo!
[QUOTE=Trew;10036073]Are you using DVD-R or DVD-RW? You should be using -R.
Im using a DVD-r
Old Sep 28, 2008 | 05:24 PM
  #53
cmt1's Avatar
As far as I know, the iTunes AAC files are encrypted so you cannot use them with any other non-DRM (Digital Rights Management) application. There are a few programs out there that claim to be able to break the encryption - but some are of dubious origin, and I imagine all will anger Apple greatly.
The way I prefer to do this, is the long way around - but it yields the highest quality and flexibility IMHO... From iTunes, burn a CD-RW with the purchased music. Then use any other application to Rip the music to WAV. It may not be the fastest way - but it works.
+1 on this... works every time.
Old Sep 28, 2008 | 05:30 PM
  #54
KzooTL's Avatar
05' AT SSM
I wish Radiohead had 5.1 albums i could buy, for people who don't have Ipod adapters this is very good news.
quik22
Aug 3, 2007 11:32 PM
acuralvr1
67
May 26, 2007 09:35 PM
JonDeutsch
Mar 13, 2004 11:32 PM
gregory28
Nov 19, 2003 09:49 AM
