Just Adding a Sub
Old Jun 19, 2010 | 06:59 PM
sysfailure0x5a's Avatar
Just Adding a Sub
I've decided to unhook my 8" stock sub and install one of these:
http://mobile.jlaudio.com/products_subs.php?series_id=6
JL Audio 10W6
Problem is I have been searching around the forum, and seem a bit confused. I am only adding a sub, everything else will be stock. I read a great tutorial on how to run the power cable from the battery.
How exactly do I hook up an aftermarket amp to the Acura TL 2005? From what I have read the TL has no RCA's on the head unit.
How do I get audio signal to the amp? How about on/off signaling from the head unit?
Old Jun 19, 2010 | 07:35 PM
tragichero's Avatar
My Other Ride is a Huey
Need to get a Line output converter (LOC), you hook the stock wires to it and it gives you RCA out. Then hook RCA's to that to your new amp. For the remote wire, i used the add a circuit method. It hooks into a blank fuse location under the driver side dash and run to the remote turn on to the amp.
Search around, then info's out there.
Old Jun 19, 2010 | 08:13 PM
Yeah, I did some searching around but didn't quite find what I was confused about. It seemed as if everyone already knew what you told me, and was building a system without mentioning these basics.
I'll run a search for a LOC, I hope they are cheap. Ill look into "adding a circuit". Seems like a good alternative. I assume it on/off's the amp by providing power when the ignition starts and cutting it when the key is off.
Old Jun 20, 2010 | 03:24 AM
tragichero's Avatar
Yea, the LOC's run about $20 and higher, i just picked mine up from advanced auto parts and it works like a charm. With the "add a circuit" route, as long as the key is in the accessory position, your amp will turn on.
Hope this helps! Let me know if you have any more questions.
RLX-Sport Hybrid
3G RLX (2013+)
27
Dec 7, 2018 12:11 PM
datadr
Mar 23, 2016 01:39 PM
navtool.com
Sponsored Sales & Group Buys
87
Jan 23, 2016 01:25 PM
merc009
Sep 29, 2015 03:06 PM
Froid
Sep 27, 2015 06:16 PM
