Issues with Dice R4
Issues with Dice R4
I have it hooked up to my 2005 TL and my 1G Nano
1. Random mode
I have to press the SCAN button every single time I turn on the car -- sometimes it'll be in SCAN mode and all of a sudden, it'll be back in NORMAL mode.
2. Paused/stopped when starting the car
When this happens, I switch to another MODE (FM, CD etc), then switch back to XM and it starts to play again.
What's the deal? Does anyone else have these issues? Should I call Dice?
TIA
1. Random mode
TIA
i had issues with mine where it would just stop playing and freeze. i had to unplug the dice module and plug it back then it would work for a few weeks then freeze again. i had it the dip switches under xm emulation because i wanted the titles on my nav screen, but when i got xm i switched it to cdc emulation and it's work flawlessly ever since. i dont get the track titles on the screen any more but its faster scrolling thru the ipod itself anyway. plus you can still track advance with the steering wheel remote
TIA
TIA
RC5-I think the pause issue is normal since its working off the XM. It wouldn't pause the XM either if you used your phone.
My issue is the text on my clock display only says DICE or NO INFO ever since I had to jump start my car. The text works fine on the nav screen, but now I can't be on the map screen and still read what is playing in the clock display. Pretty frustrating since it used to work like that.
We used to have some DICE reps on the forum that would chime in and help, where'd they go?
Another thing I noticed is that the scrolling feature works intermittently. I'm not sure if that has more to do with the ID3 tags on the song or not. That is not a huge deal for me.
snorf
Nov 4, 2019 06:44 AM
