iSimple not working.
Old Sep 24, 2011 | 01:02 AM
wheelman322's Avatar
I bought the car used with this in it, and I can't get it to work...figure I'm doing something wrong. To make it as simple as possible, I plug the iPod into the connector, it states "iPod is not supported by this device", I turn the head unit on & attempt to access the XM function...no luck...Here's a pic of the device...
Old Sep 24, 2011 | 09:24 AM
ez12a's Avatar
the overexplainer
Looks like you're using an ipod that isnt supported. Looks like the Gateway is working (iPod isnt something you normally see in the radio) Try updating the firmware by downloading the proper file here: http://www.pac-audio.com/firmware/index.html
Also that Gateway is an older model. The firmware may still work.
Old Sep 24, 2011 | 12:01 PM
Thanks...I'll let you know how it turns out.
Old Oct 7, 2011 | 12:20 AM
prowheelie92's Avatar
well tht device is the old one. what i would do is update your ipod then if that dosent work update the unit. it isnt hard just follow step by step instructions.
Old Oct 12, 2011 | 11:52 AM
That looks like the next step...I updated the firmware & attempted a reconnect...No luck...I did some more hunting here & seen that another forum member had luck by flipping the 2nd switch down, so I tried that...everything worked normally, but no sound...am I missing something or should I update the unit?
Old Oct 31, 2011 | 03:31 PM
Ltrain118's Avatar
9th Gear
I just bought a use car and it has a isimple dont know what model my car is a 04 none navi and it does play any audio but it charges my iphone 4 and my old ipod nano iam new to this
bymotion
Nov 18, 2015 11:28 AM
MoAbbas
Oct 3, 2015 07:44 AM
DementiaPhuro
Sep 29, 2015 05:31 PM
rboller
Sep 23, 2015 02:49 PM
Vejey Gandier
Sep 12, 2015 08:59 PM
