iSimple - No 'XM' option at all
Old Apr 12, 2012 | 03:40 PM
maharajamd's Avatar
This may sound completely absurd, and I'm ashamed to say, but I installed a iSimple (ISIM71?) last year and it never worked. And quite frankly it was a whore to install and I haven't felt like taking the damn console out to redo the job. But I thought I would post up and see what you all say.
  • When I plug in the phone I get nothing. No change on the phone, no charging, etc.
  • When I switch from FM/AM to XM the radio does nothing. Actually it's like XM isn't there at all. FM->XM button just keeps you on FM.
Basically what I'm asking is with no XM option at all, did I simply not plug a harness in all the way? The white tab switches in the wrong position? Is there an easier way to get your hands behind the radio?
I mean if I didn't plug that harness in all the way it's gotta be just barely not in. So all I need is some good leverage. Can you get to there from the passenger side?
Old Apr 12, 2012 | 03:51 PM
maharajamd's Avatar
I know I know, horribly vague and noob question.
I'm just trying to save my back here. Lol
Old Apr 12, 2012 | 03:56 PM
SharksBreath's Avatar
BANNED
^in for answers. i ran into the EXACT same issues. altho my iphone will charge with the cord...i get no display and no XM option.
Old Apr 12, 2012 | 04:48 PM
maharajamd's Avatar
It's actually the ISIM73 iSimple Gateway. I've crawled under the dash and verified that everything is good on the iSimple itself. I guess I just didn't plug in the main harness completely?!?!
I remember once hearing a good way to install this without removing the console. Anyone remember?
Old Apr 12, 2012 | 05:05 PM
dano4o8's Avatar
Ran into this problem with my 07 TL-S and it was so frustrating. I called Isimple about the problem and the guy basically said "you got the wrong model" and he wasn't sure what the right one was! Horrible customer service so i got rid of it.
Old Apr 12, 2012 | 05:52 PM
guitarplayer16's Avatar
Wow, I just bought an iSIM71 for 30 bucks brand new from a local.
It better work!
The iSIM71 comes with the Honda/Acura and Toyota/Lexus harness, and it even states the TL as compatible.
Old Apr 12, 2012 | 06:21 PM
maharajamd's Avatar
Yea I mean I didn't buy the wrong model. I think I just didn't snap the main harness on the back on the radio in.
Tips on how to get access and leverage is what I'm looking for...
Old Apr 12, 2012 | 06:23 PM
Did you actually take your radio out?
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/i-058-just-installed-peripheral-electronics-isimple-ipod-adapter-review-install-tips-697728/
Old Apr 13, 2012 | 07:45 AM
maharajamd's Avatar
https://acurazine.com/forums/showthread.php?t=697728
Nope I did this when I did my short shifter install. So I had the console/dash mostly off. Looking back I should have just taken out the radio. Instead I basically just followed the link you posted. I just had a little better access.
Old Apr 13, 2012 | 07:48 AM
BANNED
guitarplayer, post a link for the 07-08 models where we have to hook it up in the trunk!
Old Apr 13, 2012 | 08:55 AM
imj0257's Avatar
Q('.')=O
You know I was thinking of getting the isimple but now I have my doubts. I hear people say install was easy and it works fine and others say it was a bitch to install and have problems with it. Knowing me, it would be a bitch to install and I would have problems with it. I am going to look more into the bluetooth streaming option.
Old Apr 13, 2012 | 10:19 AM
Mug's Avatar
Mug
I have an 07 and it wasn't too bad. I think if you have pulled your dash apart once before, the job turns from a bitch to fine. I've had my dash all apart before so taking the one side apart was easy.
If I remember correctly, I only had to pull the drivers side trim piece off to access the screws that hold the side cover on. From there I could access the harness. It was tight, and I probably cut up my hand on the metal, but I got mine in without pulling the deck.
I had problems getting it to connect. I had to upgrade the firmware. But that could be due to new phone software.
Here are some pics: https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/new-isimple-connection-text-but-no-sound-791738/
Old Apr 13, 2012 | 12:53 PM
maharajamd's Avatar
I'm going to give this another go tomorrow morning. I hope my back, and hands, can handle it. Lol
Old Apr 14, 2012 | 03:24 AM
yah yah's Avatar
Very basic. i have the isim73. plug all harness in order and turn the dip switches up. everything should connect.
if you want XM you will need a y- connector
yah yah's Avatar
if not update all ur firmware phone/isim
Old Jan 8, 2013 | 05:35 AM
boy9enius's Avatar
smh... months later and im having the same problem. i picked up a used ishd571 and after the install i have no option for XM. if i press the disc button itll go to cd. if i press am/fm button itll go to am/fm... however when i press the xm... no dice any help would be appreciated and yes im using the search button... not seeing many people with my issue. oh and yes when the ipod is conected it charges so i know its getting power. i even did a reset on the box like 3 times. also did an firmware update.
Old Jan 8, 2013 | 07:11 AM
BANNED
^i have the same issue on my 07 TL-S. i get power from the apple composite cord, but no option to select XM radio to play my ipod, etc.
very frustrating.
Old Jan 8, 2013 | 07:38 AM
boy9enius's Avatar
very frustrating.
seeing that you havent gotten it fixed since april ill be having the same problems.. i might have to look into usaspec.
frustrating.. yes it is
Old Jan 8, 2013 | 07:43 AM
BANNED
^well i haven't even attempted to fix it.
my apple composite cable will still play music through my iphone/ipod but i can't scroll with the steering wheel controls and/or see the text on my nav display and all that good stuff. i have to manually shuffle with my iphone and that's just not safe while driving.
Old Jan 8, 2013 | 07:37 PM
pohljm's Avatar
I had a very similar problem where after the install it was like it was not connected and not being recognized. I had to open up the iSimple module and hard reset it. There were instructions regarding this with the unit. after I did that it has worked beautifully ever since.
Old Feb 3, 2013 | 08:31 AM
Luqman's Avatar
very frustrating.
I have an '08 w/ XM NavTraffic so I had to install the iSimple in my trunk. Just did the install last night and initially ran into the same issue as the both of you --> the XM button didn't work on my stereo any more.
Read through the manual and it stated that the dip switch #2 should be switched on (down). Reinstalled it and (almost) everything worked fine.
Only problem I'm having is that the steering wheel controls do something really friggin annoying: the CH up & down buttons don't change the track being played but the Repeat settings on my iPhone. WTF?!
Old Feb 4, 2013 | 04:15 PM
imakeholesinu's Avatar
I'm running into the same issue. Sometimes when I start the car I will be able to use my XM button to get to the Aux1 or iPod mode. Other times I turn the car on and get a blank display. This just started happening in December.
Old Sep 10, 2013 | 07:35 AM
maharajamd's Avatar
Lol I'm bumping this thread. I pulled this unit over the weekend and finally, after getting to work and using the single only PC in my life, I updated the firmware. I'm not entirely sure as I wasn't paying full attention but I believe it had a 3 series number to start and an 8 series to finish. So I quit behind on the firmware.
Anyway, that all went fine. Get it in the car and still absolutely nothing. No charge on the iPod Nano, no XM. If I plug the OE XM plug back in it works fine.
I also did the short circuit hard reset and I attempted to switch pins like they say can work on their website. Nada.
Probably going to give them a call today and thought I'd bump my old thread.
Old Sep 10, 2013 | 11:17 AM
dontTL'em'nothing's Avatar
riding low and steady
did you cycle through the options to see if you have any feedback? You should see Aux 1, Aux 2, Ipod and XM when you cycle through.
I would check the switches. Have you tried different devices?(iphone,ipod touch)
Old Sep 10, 2013 | 11:50 AM
maharajamd's Avatar
I've tried i4s, i5s with adapters, and an iPod Nano. Nothing.
No options at all. If I hit the XM button it literally does nothing. If the real XM plug is plugged in XM works just fine.
Old Sep 10, 2013 | 12:15 PM
I dont know a better way to ask this but do you know how to cycle through the options as far as aux 1, aux 2, ipod and xm goes?
edit: i think im misunderstanding your op.
all of my dip switches are up.
Old Sep 10, 2013 | 12:39 PM
sorry admin my video didnt upload in time to make the 15 min edit time frame. Can a mod merge post please.
Old Sep 10, 2013 | 12:55 PM
maharajamd's Avatar
All my dips are off, as instructed. Yep I know how to switch once in the XM menu. But I have no XM menu at all. The button does nothing.
Thanks for the help though man!
Old Sep 10, 2013 | 01:01 PM
lol like the edit above i misunderstood your op. well the video will help someone atleast
Old Mar 13, 2014 | 02:37 AM
tode112's Avatar
5th Gear
Has anyone been able to solve the missing XM issue?
I just installed the iSimple ISHD651 for my 2006 TL (with NAVI) and am running into this issue. No matter what I do, I can't get the unit to work. I'm on the verge of returning the unit.
Some things to note during my install/troubleshooting:
- When I switch from FM/AM to XM the radio does nothing. Actually it's like XM isn't there at all. FM->XM button just keeps you on FM. (just like maharajamd mentioned)
- I've tried hitting the reset switch many times with no success.
- When the car is off, all 3 LED colors(red, yellow, green) on the iSimple device are on, and the iSimple device can get power because I am able to charge my phone via the USB port. However, when I turn the car on, my phone stops charging. At the moment I turn on the car, only the GREEN LED stays on for some time(maybe ~15 seconds), then all LEDs turn off as if power to the device gets cut off or something.
- The firmware on the label of the unit is "Connect_187a.45d", which is the latest available from the site (http://www.pac-audio.com/Firmware/connect/index.html)
Old Mar 13, 2014 | 11:11 AM
pohljm's Avatar
You need to do a hard reset. Open up unit and short out the larger capacitor in the group. That always works for me when that happens. If you replace your battery you may need to do this. You can get detailed instructions from tech support.
Old Mar 14, 2014 | 01:24 AM
tode112's Avatar
5th Gear
What iSimple device do you have? And are you referring to this reset procedure?
http://www.pac-audio.com/PACProductD...xaux_reset.pdf
If so, for the new ISHD651 (Connect) device that I have, they added a reset cable/button to avoid having to open the unit to perform the procedure. I tried resetting using the button many times but it didn't fix it.
Old Mar 14, 2014 | 12:43 PM
pohljm's Avatar
That is correct procedure. Reset button did not work for me either. Discharging the capacitor works
Old Mar 16, 2014 | 02:38 AM
tode112's Avatar
5th Gear
Unfortunately I already returned the unit before I could try out this capacitor discharge method.
I have another new unit (ISHD651) coming in the mail. I'll update on what happens with that one once it arrives.
Old Mar 16, 2014 | 03:59 AM
mzilvar's Avatar
I can say that if the XM unit is not plugged into the headunit it will not allow you to go to the XM option at all.
I was going to delete my XM radio by removing it from the trunk, but with it disconnected I could not get to XM at all on the radio even though the harness was still plugged into it.
Did you make sure that the OEM XM connector is also plugged into the harness for the iSimple?
One connector goes to the OEM cable that goes back to the XM radio, one connector goes into the headunit and a third goes onto the iSimple.
Old Mar 16, 2014 | 01:26 PM
tode112's Avatar
5th Gear
Yeah I made sure all 3 connections were correctly performed. I did the install probably at least 4 different times to troubleshoot the issue, so I'm fairly certain there were no issues with the OEM XM connection being made to the harness.
I appreciate the suggestion though!
Old Mar 22, 2014 | 04:45 PM
tode112's Avatar
5th Gear
I just received the new unit and wanted to give a final update.
With this new unit, it worked right out of the box. I did not see the missing XM issue at all.
So I guess for anyone that is still seeing the issue, you can try out pohljm's capacitor discharge method to see if it will fix the problem or not.
Old Mar 24, 2016 | 02:54 AM
Ryan Ballinger's Avatar
Fix for isimple
I mean if I didn't plug that harness in all the way it's gotta be just barely not in. So all I need is some good leverage. Can you get to there from the passenger side?[/QUOTE]
Old Mar 24, 2016 | 12:47 PM
pohljm's Avatar
No it's plugged in I bet. You need to open up the iSimple and do a hard reset by discharging the largest capacitor. I just had to do this again yesterday after battery replacement
Old Mar 24, 2016 | 01:24 PM
maharajamd's Avatar
Hah, old thread!
I finally pulled the iSimple unit last summer and.........threw it in the trash! Good riddance!
