Ipod Text Display Selection
Old Jan 24, 2009 | 03:55 PM
Fred99x's Avatar
06 WDP TL Owner
I've recently installed the NEO ipod adapter and it plays great. I have the 06 Canadian TL with Navi and have full text display. Here's my question. The smaller upper display always shows the song title. Is it possible to change this to display the song artist? I know it displays on the navi screen but I don't have the navi on by default so I'd like the upper display to show the artist. I'm also attempting to discover some of the undocumented ipod controls.
-press and hold head unit #2 preset will activate/deactivate random selection.
-press #3 head unit preset will jump forward 10 songs.
-seek buttons switch between playlists.
-scan button scans songs.
Any others? I know that functions depend on which ipod adapter is installed but there may be some commonality between the units.
Old Jan 24, 2009 | 09:53 PM
datmrman's Avatar
I believe the Neo adapter is very similar to the USA Spec. Have you tried pressing the "Display" button below the navi?
Old Jan 25, 2009 | 05:39 PM
Fred99x's Avatar
06 WDP TL Owner
There's no Display button on the Canadian navi. I believe the Audio button does the same function which displays all the text data from the ipod.
][/URL]
Old Jan 26, 2009 | 11:39 AM
datmrman's Avatar
Can you post a bigger picture? There isn't a link to the full size image from the thumbnail.
Old Jan 26, 2009 | 02:33 PM
Mattgtp's Avatar
06 6mt A-Spec Navi
What model of neo did you get? Just wondering because mine doesn't show text and now im jealous
Old Jan 26, 2009 | 05:43 PM
Fred99x's Avatar
06 WDP TL Owner
Ok, the thumbnail was working but let's try this again.
Here is the model of NEO that I purchased:
http://www.icarkits.com/advanced_sea...icle=1&sort=4d
The head unit on my TL is a model 1TB3 which is indicated on the cassette door. If you have this head unit, it is text capable.
Old Jan 26, 2009 | 08:39 PM
ladiesman217's Avatar
e92 335i
fred a couple of questions .. i have 2006 TL w/ navi so its safe to say this neo adapter should work the same it works for u for me as well? also i was wondering where does the wire you hook up your ipod to come out of? do you have any other pictures i can see? and lastly is it possible to hook up any other mp3 devices like a mp3 player with a 3.5 mm jack and not just the ipod because on the website product link it says it is also has aux inputs
Old Jan 26, 2009 | 08:42 PM
Mattgtp's Avatar
06 6mt A-Spec Navi
Well I have the same headunit but I guess my Neo is an older model, can't tell because it does not have a model number on the unit but I dont get text display just displays CD numbers and tracks
e92 335i
and how did u manage to get the xm screen displaying the music and artist being played on your navigation system when our cars didnt come with xm till the 07 + model?
Old Jan 26, 2009 | 08:43 PM
e92 335i
i think you need this model number PODHONR3V215
Old Jan 26, 2009 | 08:51 PM
Mattgtp's Avatar
06 6mt A-Spec Navi
Ya mine must be older(got it 2 years ago) but it has no part number on it, looks the same but maybe an older version. On mine you have the standard left/right aux input no 3.5mm plug
Old Jan 26, 2009 | 08:57 PM
e92 335i
so if i bought the new one that fred has i wouldnt be able to use my psp or blackberry with it?
Old Jan 26, 2009 | 09:06 PM
Mattgtp's Avatar
06 6mt A-Spec Navi
No I don't think it will work but maybe you could look for a cable that is 3.5mm on one end and has the other conections on the other. I've seen them out there before but not sure what the sound quality would be.
Old Jan 27, 2009 | 12:02 PM
Fred99x's Avatar
06 WDP TL Owner
Ladiesman: if your head unit is the same model number, it should work but I can't guarantee this. The NEO kit provides two short head unit cables. One is a straight through cable and the other is a Y cable. I used the straight through cable as there was nothing connected to the head unit port. From the end of the head unit cable, a long cable is run to the NEO unit which you can mount in the bottom of the console or under the driver seat. Another long cable is run from the NEO unit to the ipod itself. My ipod is located in the bottom of the console and I never access it.
There is an auxilary jack for any kind of audio output device which puts out a left and right channel output. From the dealer: "The PODHONR3V215 now features additional auxiliary inputs which allow users to connect another audio device, in addition to the iPod. Any device connected through the auxiliary inputs will also be played on the factory radio in CD Quality Sound, just like the iPod." Thus any mp3 player can connect.
Once the NEO unit is connected, by pressing the mode button on the steering wheel, you can scroll through the various inputs until you get to XM. The NEO unit simulates XM. Without the NEO unit connected, you will not see the XM option.
Hope this helps you out.
Old Jan 27, 2009 | 12:05 PM
e92 335i
thanks for the info fred, do you have any pictures of where the ipod wire is mounted? do you think it can be fed through to the armrest console..and do you think futureshop or bestbuy will be able to do this installation? thanks a million
Old Jan 27, 2009 | 01:56 PM
Fred99x's Avatar
06 WDP TL Owner
When I did the installation, I followed the directions in one of the other posts where you take off the console drivers side panel. You then run the cable inside the console and by cutting a small corner of the cover located in the bottom of the console, you can run the wire into the console. You can leave the NEO unit in the bottom of the console. You can then leave the ipod there as well or the cable is plenty long to locate the ipod outside the console if you want. Any good card audio shop can do the installation. I would think Furture Shop or Best Buy could also do this install as it is fairly simple.
Old Jan 27, 2009 | 02:12 PM
e92 335i
thanks fred appreciate it alot, and pictures of your setup if you dont mind thanks again fellow canadian
Old Jan 27, 2009 | 05:51 PM
Fred99x's Avatar
06 WDP TL Owner
Here is a picture of the NEO unit showing the aux input. Currently I have it tucked under the driver seat but I'm going to move the unit to inside the bottom of the console.
Here is a photo of the ipod in the console. The coiled cable is my cell phone charger.
Old Jan 27, 2009 | 07:57 PM
e92 335i
appreciate it fred. thanks again.
Old Mar 7, 2009 | 03:35 PM
Deep 3.2TL's Avatar
Hey Fred99x,
I'm in the exact same boat as you - I have an 06 Canadian TL with Navi.
I don't have an integration kit yet, and the fact that you've installed it into the same car is a real plus for me.
How hard was the install? What selection do you press to listen to the iPod? (IE CD plays CD's, AM plays AM radio, etc)
Old Mar 8, 2009 | 01:04 AM
e92 335i
keeping pressing mode on the steering wheel after installing the adapter, and XM will appear along with the song title/artist info
Old Mar 9, 2009 | 01:45 PM
Fred99x's Avatar
06 WDP TL Owner
Installation was a piece of cake. I did remove the console side panel which I think is a must. The hardest part is removing the silver console trim. You have to be careful as the clips are stuborn trying to get off. See this post for more info.
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/ipod-off-function-adapter-699339/
Old Mar 10, 2009 | 12:00 AM
cdAspec's Avatar
i have an 05 TL with navi. whats the wud yall suggest would work best for an Iphone?
Old Mar 10, 2009 | 05:10 PM
Deep 3.2TL's Avatar
Any Canadians reading this - I've found the USA Spec units PA15HON2 in Canada locally (Oakville) for $149 CAD. That's a great price considering exchange, shipping, brokerage, etc.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
InFaMouSLink
Oct 27, 2015 06:52 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
